I created a question before: Wifi is fine on Ubuntu but very slow on window 7
And I found a solution by running this command: sudo modprobe -r b44 b43 b43legacy ssb brcmsmac wl || sudo modprobe brcmsmac
But everytime I restart my computer, I must run it again. If not, other computer in my network will have slow connection. And my questions are:
1. Why wl mode is the reason?
2. How to set permanently this configuration?
Thank for your attention :-)
Blacklist the kernel modules you don't want to load in the first place by putting them in a file in /etc/modprobe.d/ like this:
  1. Create the file /etc/modprobe.d/blacklist-mywireless.conf
    sudo gedit /etc/modprobe.d/blacklist-mywireless.conf
  2. For each module you don't want to load at bootup, put on a single line: blacklist modulename, e.g.:
    blacklist b44
    blacklist b43
    blacklist b43legacy
    blacklist ssb
    blacklist wl
  3. Save and close the file.
  4. Add a line to /etc/modules for each module you do want to load, e.g.:
    sudo gedit /etc/modules
    Append, on a new line:
    brcmsmac
  5. Save and close.
  6. Reboot.
gertvdijk
  • 69,427
In Ubuntu 13.04, I believe the default bcmwl-kernel-source will not work correctly for your Broadcom 4313. I recommend that you get a temporary wired ethernet connection and open a terminal:
sudo apt-get remove --purge bcmwl-kernel-source
wget http://us.archive.ubuntu.com/ubuntu/pool/restricted/b/bcmwl/bcmwl-kernel-source_5.100.82.112+bdcom-0ubuntu3_amd64.deb
Or, if yours is a 32-bit system:
wget http://us.archive.ubuntu.com/ubuntu/pool/restricted/b/bcmwl/bcmwl-kernel-source_5.100.82.112+bdcom-0ubuntu3_i386.deb
Confirm 32- or 64-bit:
arch
Then do:
sudo dpkg -i bcmwl*.deb
Reboot and give us your report.
chili555
  • 61,330
