I would like to monitor dconf for changes so that while I tinker with settings, applications and the like I can see what keys are changed, if any.
Is there a way I can accomplish this?
If you want real-time monitoring, you could run the dconf watch command in a terminal, either to monitor a specific schema path
dconf watch /desktop/gnome/remote-access/
or the whole tree
dconf watch /
which will show a running output as you change values, e.g. toggling the 'Desktop Sharing' security preference checkbox produces
/desktop/gnome/remote-access/notify-on-connect
false
true
If you just want a list of changes, you could use dconf dump redirected to a file to create before and after snapshots that you can then compare with diff.
