12
It is possible to print the result of 2 commands side by side...
Something like this
something `ls -l /a` `cat bla.txt`
result:
total 24                                                #while [ 1 = 1 ]; do
-rw-r--r-- 1 wolfy wolfy  194 Aug 13 08:50 c.in         #       echo "bla"
-rwxr-xr-x 1 wolfy wolfy   52 Sep 24 11:48 bla.sh       #done
-rwxr-xr-x 1 wolfy wolfy   38 Sep 24 11:48 bla1.sh      echo "bla"
-rwxr-xr-x 1 wolfy wolfy  147 Sep 24 11:54 ble.sh
I know that pr can do something like this with files, but I didn't find a way to do this for commands...
Wolfy
  • 8,050
You can use process substitution
pr -m <(cmd1) <(cmd2)
though in your case, since you have one command and one file:
ls -l | pr -m - bla.txt
geirha
  • 47,279
TL;DR
Consider using a combination of paste / column rather than pr to get more consistent results.
  • Depending on your OS, pr incorrectly mixes in the columns when input lengths differ (Ubuntu, macOS) or even worse will print each input on a completely different pages (Centos 7)
  • pr both prepends and appends extraneous output
FORMAT:
paste <(cmd1) <(cmd2) | column -s $'\t' -t
Detailed Explanation
A highly robust solution is possible through a combination of the paste and column commands.
Advantages of the paste / column approach over pr:
  • Cleaner output due to no timestamp or page header information being prepended, nor a full screen of empty lines appended
  • Columns always stay separate even when the input lengths are different
Concrete example:
paste <(ls -1 .) <(ls -1 ..) | column -s $'\t' -t
Real-life output of paste / column technique on Ubuntu 16.04:
jay-z@jaytaylor.com:~/go/src/github.com/jaytaylor/html2text
$ paste <(ls -1 .) <(ls -1 ..) | column -s $'\t' -t
LICENSE            archiveify
README.md          go-hostsfile
html2text.go       html2text
html2text_test.go  jaytaylor
testdata           mockery-example
shipbuilder
stoppableListener
tesseract-web
See also: combine text files column-wise
For Comparison: pr on various platforms
TL;DR: pr behavior is inconsistent across Linux flavors.
Output of pr version on Ubuntu:
$ pr -m <(ls -1 .) <(ls -1 ..)
2017-05-25 15:50                    /dev/fd/62                    Page 1
LICENSE                 archiveify
                    shipbuilder
                    stoppableListener
                    tesseract-web
Output of pr version on OS X / macOs:
May 25 08:55 2017  Page 1
LICENSE                 archiveify
                    shipbuilder
                    stoppableListener
                    tesseract-web
<... remainder of screen filled with blank lines ...>
Output of pr version on Centos:
(Surprisingly the behaviour of pr under Centos 7 differs from that of all other platforms tested)
$ pr <(ls -1 .) <(ls -1 ..)
2017-05-25 15:59                    /dev/fd/63                    Page 1
LICENSE
README.md
html2text.go
html2text_test.go
testdata
2017-05-25 16:21                    /dev/fd/62                    Page 1
archiveify
go-hostsfile
html2text
jaytaylor
mockery-example
shipbuilder
stoppableListener
tesseract-web
You can use screen like this:
In screen type Ctrl-a | for vertical and Ctrl-a S for horizontal split.
  • jump to next display region: Ctrl-a Tab
  • remove current region: Ctrl-a X
  • remove all regions but the current one: Ctrl-a Q
start ls -l /a in the right half and cat bla.txt in the left.
gertvdijk
  • 69,427
chaos
  • 28,186
