16
What is the most correct method of installing apache 2 server, php5, mysql and phpMyAdmin?
I installed it this week, and I had a lot problems without solutions, so now that I reinstalled Ubuntu 13.04 I don't want to make the same mistake again.
karel
  • 122,292
  • 133
  • 301
  • 332
L.V.A
  • 1,174
6 Answers6
13
From a command line:
sudo apt-get install tasksel
sudo tasksel install lamp-server
https://help.ubuntu.com/community/ApacheMySQLPHP
NGRhodes
  • 9,680
11
Install Apache2
sudo apt-get update
sudo apt-get install apache2
sudo apt-get install php mysql-server mysql-client php5-mysql libapache2-mod-auth-mysql php-mbstring php5-gd libapache2-mod-php5
sudo mysql_install_db
Set password for mysql
sudo /usr/bin/mysql_secure_installation
Then install the php
sudo apt-get install php5 libapache2-mod-php5 php5-mcrypt
sudo apt-get install php5-mysql php5-curl php5-gd php5-intl php-pear php5-imagick php5-imap php5-mcrypt php5-memcache php5-ming php5-ps php5-pspell php5-recode php5-snmp php5-sqlite php5-tidy php5-xmlrpc php5-xsl
Then to check the PHP
sudo vim /var/www/info.php
<?php
phpinfo();
sudo /etc/init.d/apache2 restart
Install phpmyadmin
apt-get install phpmyadmin
While installation it will ask for some settings for choosing apache server or lighthttpd choosem apache
Choose Apache
Choose no for dbconfig-common
Now Navigate to the Web Browser and openup the IP mentioned with /phpmyadmin/
eg : http://192.168.122.69/phpmyadmin/
Use Your Login what u used for mysql installation
Login Information I always use for demo purpose is
root and password is admin123
The quickest and my favorite is - open the terminal and type
sudo apt-get install lamp-server^ phpmyadmin
chesedo
  • 1,749
  • 14
  • 25
I've developed some steps to install php 5.3 + Apache on Ubuntu 14.
First, write the following repositories to the file /etc/apt/sources.list.d/ubuntu-old.list
deb http://55.archive.ubuntu.com/ubuntu/ trusty main
deb http://security.ubuntu.com/ubuntu precise-security main universe
deb http://cz.archive.ubuntu.com/ubuntu precise main universe
run apt-get update and then
sudo apt-get install php5=5.3.10-1ubuntu3.19 php5-cli=5.3.10-1ubuntu3.19 php5-common=5.3.10-1ubuntu3.19 libapache2-mod-php5=5.3.10-1ubuntu3.19 apache2=2.2.22-1ubuntu1.9  apache2-mpm-prefork=2.2.22-1ubuntu1.9 apache2.2-common=2.2.22-1ubuntu1.9 apache2.2-bin=2.2.22-1ubuntu1.9 php5-pgsql=5.3.10-1ubuntu3.19 php5-xdebug=2.1.0-1
I've tested each command, it worked fine!
s_bighead
  • 111
  1. ALWAYS
    sudo apt-get update
  2. Basic:
    sudo apt-get install apache2 php5-common mysql-server libapache2-mod-auth-mysql php5-mysql
  3. Extras:
    sudo apt-get install php5-dev php5-gd
  4. Make sure you ALWAYS run mysql_secure_installation after you have installed MySQL
A.B.
  • 92,125
macjules
On Ubuntu 13.10 I had an error installing phpmyadmin:
 javascript-common
When I loaded the page in my browser it came up as:
error: json missing
Found the answer here: https://superuser.com/questions/639945/how-to-fix-the-phpmyadmin-error-json-extension-is-missing.
