I am installing package RCurl in R and getting an error
checking for curl-config... no
Cannot find curl-config
ERROR: configuration failed for package ‘RCurl’
I have tried to install libcurl on Ubuntu, but it doesn't solve my problem have some dependecies
sudo apt-get install libcurl4-gnutls-dev
libcurl4-gnutls-dev : Depends: libcurl3-gnutls (= 7.29.0-1ubuntu3.1) but 7.29.0-1ubuntu3.2 is to be installed
Depends: libldap2-dev but it is not going to be installed
locate curl config gives me nothing:
locate curl-config
curl-config
The program 'curl-config' can be found in the following packages:
* libcurl4-gnutls-dev
* libcurl4-nss-dev
* libcurl4-openssl-dev
I went through some of the solution RCurl but it is working. Can you suggest or help in this direction. Thank you so much.
Edit
when i tried to install(Curl) from Ubuntu Software center got the same erroe message
Package dependencies cannot be resolved
This error could be caused by required additional software packages which are missing or not installable. Furthermore there could be a conflict between software packages which are not allowed to be installed at the same time.
curl: Depends: libcurl3 (= 7.29.0-1ubuntu3.1) but 7.29.0-1ubuntu3.2 is to be installed
Depends: zlib1g (>= 1:1.1.4) but 1:1.2.7.dfsg-13ubuntu2 is to be installed
EDITED
sudo aptitude install libcurl4-openssl-dev
The following NEW packages will be installed:
libcurl4-openssl-dev{b}
0 packages upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,210 kB of archives. After unpacking 2,778 kB will be used.
libcurl4-openssl-dev : Depends: libcurl3 (= 7.29.0-1ubuntu3.1) but 7.29.0-1ubuntu3.2 is installed.
Depends: libidn11-dev but it is not going to be installed.
Depends: libkrb5-dev but it is not going to be installed.
Depends: libldap2-dev but it is not going to be installed.
Depends: librtmp-dev but it is not going to be installed.
Depends: libssl-dev but it is not going to be installed.
The following actions will resolve these dependencies:
Keep the following packages at their current version:
1) libcurl4-openssl-dev [Not Installed]
