I am new to Ubuntu (12.04.3). I installed the software to my laptop http://www.lapwik.com/hp-compaq_6735s for typical use (browsing, movies, music ,etc.) I am not a programmer and I can't understand what is happening with programs and drivers. I am not able to download the drivers because I don't have access to the internet because of my network card, I think I found a driver for my network PCI, but I don't know how to use it (http://www.broadcom.com/support/802.11/linux_sta.php)
Any help?
karel
  • 122,292
  • 133
  • 301
  • 332
Try install instructions:
mkdir hybrid_wl
cd hybrid_wl
download it :
if you have ubuntu 32bit
wget http://www.broadcom.com/docs/linux_sta/hybrid-v35-nodebug-pcoem-6_30_223_141.tar.gz
if you have ubuntu 64bit
wget http://www.broadcom.com/docs/linux_sta/hybrid-v35_64-nodebug-pcoem-6_30_223_141.tar.gz
extract it
tar xzf hybrid-v35-nodebug-pcoem-6_30_223_141.tar.gz
  1. Build the driver as a Linux loadable kernel module (LKM):
make clean (optional)
make
When the build completes, it will produce a wl.ko file in the top level directory.
If your driver does not build, check to make sure you have installed the kernel package described in the requirements above.
This driver uses cfg80211 API. Code for Wext API is present and can be built but we have dropped support for it. As before, the Makefile will still build the matching version for your system.
make API=CFG80211
or
make API=WEXT (deprecated)
make sure you installed :
sudo apt-get install build-essential linux-headers-generic
sudo apt-get build-dep linux
