How to get rid of the text that appears at the bottom of all toolbar icons? It suddenly has shown up after a system crash although I didn't change anything and now I can't make it disappear:
I tried to set the following setting with dconf-editor:
org.gnome.desktop.interface toolbar-style
to the value ›text‹ and logged out and in, but didn't help at all. What to do?
UPDATE: The setting in gconf is correct as shown by the screenshot: enter image description here
user5950
  • 6,406
Run the following command in terminal:
gsettings set org.gnome.desktop.interface toolbar-style 'icons'
The other valid values are: 'both', 'both-horiz', and 'text'.
The changes should be visible immediately, so you don't need any restart or re-login.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
I found out that this problem occurs when the Cinnamon ppa ppa:gwendal-lebihan-dev/cinnamon-stable is used. It is related with:
Nemo 2.0 does not render desktop correctly with Compiz
GTK2 applications are not themed correctly
Purging the ppa resolves all of those tree problems:
sudo ppa-purge ppa:gwendal-lebihan-dev/cinnamon-stable
user5950
  • 6,406
