-1
Trying to start 13.04 after a recent installation.
A window appears that says "Cannot correctly detect the screen, graphics card, and input device settings" You will need to set these yourself. Standby as display restarts" Then there is only a terminal window, which says "* Checking battery state ... [ok]" and it just hangs there and does nothing and does not respond to any input"
any suggestions?
thanks, stephen
So I reinstalled 13.04 after struggling with modifying the boot commands which didn't seem to accomplish much. I gave a larger disk space allocation, it started fine.
thank you all for your help
thanks stephen
-1
Install the system again or it is better to have 12.04. I think it supports more hardware stuff. Check this link
https://help.ubuntu.com/13.04/installation-guide/index.html
Maybe you will find an answer
