I'd like to use anacron for a weekly job on Ubuntu 13.04.
Here's my /etc/crontab:
# /etc/crontab: system-wide crontab
# Unlike any other crontab you don't have to run the `crontab'
# command to install the new version when you edit this file
# and files in /etc/cron.d. These files also have username fields,
# that none of the other crontabs do.
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
# m h dom mon dow user command
17 * * * * root cd / && run-parts --report /etc/cron.hourly
25 6 * * * root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
47 6 * * 5 root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
52 6 1 * * root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
here's my /etc/anacrontab:
# /etc/anacrontab: configuration file for anacron
# See anacron(8) and anacrontab(5) for details.
SHELL=/bin/sh
HOME=/root
LOGNAME=root
# These replace cron's entries
1 5 cron.daily run-parts --report /etc/cron.daily
7 10 cron.weekly run-parts --report /etc/cron.weekly
@monthly 15 cron.monthly run-parts --report /etc/cron.monthly
Here's my /etc/cron.weekly/0anacron:
#!/bin/sh
# anacron's cron script
# This script updates anacron time stamps. It is called through run-parts
# either by anacron itself or by cron.
# The script is called "0anacron" to assure that it will be executed
# _before_ all other scripts.
test -x /usr/sbin/anacron || exit 0
anacron -u cron.weekly
And finally here's the script I put in /etc/cron.weekly/ :
#!/bin/sh
curlftpfs -o allow_other,skip_pasv_ip mauro-casa.no-ip.org:21001/Volume_1/Foto/Marta/ /home/mauro/Pubblici/Marta_NAS/
sleep 5
rsync -rlt --update --ignore-existing --size-only --exclude=.picasaoriginals/* --exclude=.picasaoriginals --exclude=.directory --exclude=.dropbox --exclude=picasa.ini --temp-dir=/home/mauro/.rsync-temp/ /home/mauro/Dropbox/Marta/ /home/mauro/Pubblici/Marta_NAS/
umount -l /home/mauro/Pubblici/Marta_NAS/
The script is obviously chmoded +x, and it works perfectly if executed manually (with sudo).
EDIT #1
As requested, here's output of
cat /var/log/cron.log | grep "Oct 13"
Oct 13 08:29:05 mauro-alienware anacron[1315]: Anacron 2.3 started on 2013-10-13
Oct 13 08:29:05 mauro-alienware cron[1266]: (CRON) INFO (pidfile fd = 3)
Oct 13 08:29:05 mauro-alienware cron[1403]: (CRON) STARTUP (fork ok)
Oct 13 08:29:05 mauro-alienware cron[1403]: (CRON) INFO (Running @reboot jobs)
Oct 13 08:29:06 mauro-alienware anacron[1315]: Will run job `cron.daily' in 5 min.
Oct 13 08:29:06 mauro-alienware anacron[1315]: Jobs will be executed sequentially
Oct 13 08:34:05 mauro-alienware anacron[1315]: Job `cron.daily' started
Oct 13 08:34:05 mauro-alienware anacron[1651]: Updated timestamp for job `cron.daily' to 2013-10-13
It seems no logs for cron.weekly is showed.
Instead, here's an extract from cat /var/log/cron.log.1 | grep "Oct 11" output:
Oct 11 06:47:01 mauro-alienware CRON[12553]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly ))
Oct 11 06:59:11 mauro-alienware anacron[5125]: Anacron 2.3 started on 2013-10-11
Oct 11 06:59:11 mauro-alienware anacron[5125]: Normal exit (0 jobs run)
Oct 11 07:45:54 mauro-alienware anacron[5444]: Anacron 2.3 started on 2013-10-11
Oct 11 07:45:54 mauro-alienware anacron[5444]: Normal exit (0 jobs run)
Oct 11 07:46:39 mauro-alienware CRON[9156]: (root) CMD (start -q anacron || :)
Oct 11 07:46:39 mauro-alienware anacron[9159]: Anacron 2.3 started on 2013-10-11
Oct 11 07:46:39 mauro-alienware anacron[9159]: Normal exit (0 jobs run)
Oct 11 08:46:31 mauro-alienware cron[1249]: (CRON) INFO (pidfile fd = 3)
Oct 11 08:46:31 mauro-alienware cron[1308]: (CRON) STARTUP (fork ok)
Oct 11 08:46:31 mauro-alienware cron[1308]: (CRON) INFO (Running @reboot jobs)
Oct 11 08:46:31 mauro-alienware anacron[1303]: Anacron 2.3 started on 2013-10-11
Oct 11 08:46:31 mauro-alienware anacron[1303]: Normal exit (0 jobs run)
Oct 11 08:46:35 mauro-alienware anacron[1839]: Anacron 2.3 started on 2013-10-11
Oct 11 08:46:35 mauro-alienware anacron[1839]: Normal exit (0 jobs run)
Oct 11 08:46:37 mauro-alienware anacron[4700]: Anacron 2.3 started on 2013-10-11
Oct 11 08:46:37 mauro-alienware anacron[4700]: Normal exit (0 jobs run)
