I have an Lenovo Ideapad S10-2 Like this
Processor / Chipset CPU Intel Atom N270 / 1.6 GHz Cache L2 cache - 512.0 KB Front Side Bus 533.0 MHz Chipset Mobile Intel 945GSE Express Features Hyper-Threading Technology
RAM 2.0 GB DDR2 SDRAM 533.0 MHz / PC2-5300 Form Factor SO DIMM 200-pin
Audio & Video Graphics Processor Intel GMA 950 Memory Allocation Technology Dynamic Video Memory Technology 3.0
Which ubuntu derivative should i use for best driver and device performans compatibility
im a general purpose user frequently surf on internet, sometimes i need remote desktop connection, office extension document files, and video multimedia files.
Your suggestions are very important for me because windows slow down my system heaps of times.. so i want to use ubuntu anymore.
Thanks in advance, Best Regards
Karl
I have a machine with almost the same specs and Lubuntu is running very smooth on it. My recommendation is to go with Lubuntu.
All will contain similar programs, so that's not a problem. Course, you could just install more if you needed to. Here's what I'd say: Lubuntu: Very fast but not quite as pretty as Xubuntu, similar Ui to win xp/vista. Xubuntu: Still pretty fast but not as fast as Lubuntu, different Ui to win. Kubuntu: Prettier than the others, much slower, similar Ui to win xp/vista or 7 if you change the panel settings. I'd recommend L- or X- ubuntu for a netbook.
Either Xubuntu or Lubuntu for low end specs, although you may be just fine with Unity if you turn off some of the pretty stuff.
