I installed GNOME 3.10. I had GNOME 3.8 and liked it very much. Unfortunately, with 3.10 it seems like something went wrong. None of the backgrounds work and the buttons to log out and shut down are missing.
How can I uninstall and reinstall GNOME 3.10? I am running Ubuntu 13.04.
I originally installed it by:
sudo add-apt-repository ppa:ricotz/testing
sudo add-apt-repository ppa:gnome3-team/gnome3
sudo add-apt-repository ppa:gnome3-team/gnome3-staging
sudo apt-get update
sudo apt-get install gnome-shell
Naomi K
  • 135
Try this, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo apt-get install ppa-purge
sudo ppa-purge ppa:gnome3-team/gnome3-staging
sudo ppa-purge ppa:gnome3-team/gnome3-next
Then reconfigure either GDM or LightDM, whichever one you like
sudo dpkg-reconfigure gdm
OR
sudo dpkg-reconfigure lightdm
If you don't get 3.8 back, do
sudo apt-get update
Mitch
  • 109,787
You can install a specific version of a package via equality sign:
apt-get install <package name>=<version>
But first you have to find out which versions are available by:
apt-cache madison <package name>
For example with the package binutils:
# apt-cache madison binutils
  binutils | 2.22-6ubuntu1.1 | http://ch.archive.ubuntu.com/ubuntu/ precise-updates/main amd64 Packages
  binutils | 2.22-6ubuntu1.1 | http://security.ubuntu.com/ubuntu/ precise-security/main amd64 Packages
  binutils | 2.22-6ubuntu1 | http://ch.archive.ubuntu.com/ubuntu/ precise/main amd64 Packages
  binutils | 2.22-6ubuntu1 | http://ch.archive.ubuntu.com/ubuntu/ precise/main Sources
  binutils | 2.22-6ubuntu1.1 | http://ch.archive.ubuntu.com/ubuntu/ precise-updates/main Sources
  binutils | 2.22-6ubuntu1.1 | http://security.ubuntu.com/ubuntu/ precise-security/main Sources
Then take one of the version numbers the command with the apt-get install command, for example:
apt-get install binutils=2.22-6ubuntu1.1
chaos
  • 28,186
