I am trying to play a movie on ubuntu and it will not work. It tells me that I need to install dvd decryption. I was researching online and found out that I need to install libdvdread4, I did that. I also read that I needed to install libdvdcss, and this is where there was a problem. I ran:
sudo /usr/share/doc/libdvdread4/install-css.sh into the terminal and got the following:
--2013-10-10 20:52:33--  http://packages.medibuntu.org/dists/precise/free/binary-i386/Packages
Resolving packages.medibuntu.org (packages.medibuntu.org)... 88.191.127.22
Connecting to packages.medibuntu.org (packages.medibuntu.org)|88.191.127.22|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2013-10-10 20:52:33 ERROR 404: Not Found.
Dynamic fetch failed; Falling back to static fetch
--2013-10-10 20:52:33--  http://packages.medibuntu.org/pool/free/libd/libdvdcss/libdvdcss2_1.2.10-0.2medibuntu1_i386.deb
I am wondering if there is any other way to install libdvdcss. Thanks
Seth
  • 59,332
Daniel
  • 55
NB: This software may be illegal in your jurisdiction due to intellectual property laws. Use at your own risk.
The script was trying to pull a package from the Medibuntu Project, which has been discontinued.
You can try installing libdvdcss from Videolan's website instead.
camconn
  • 1,894
http://packages.medibuntu.org is gone. The packages have been removed because there was no one to maintain them. Videolan still maintains these files in deb packaging. You can find libdvdcss2 here http://download.videolan.org/pub/libdvdcss/1.2.10/deb/. You will need to search for the rest but they are there
Ronshere
  • 493
