-1
$ sudo apt-get install openjdk-7-jre
[sudo] password for paul:
Reading package lists... Done
Building dependency tree
 openjdk-7-jre : Depends: openjdk-7-jre-headless (= 7u25-2.3.10-1ubuntu0.13.04.2) but it is not going to be installed
                 Depends: libgif4 (>= 4.1.4) but it is not installable
                 Depends: libatk-wrapper-java-jni (>= 0.30.4-0ubuntu2) but it is not installable
                 Recommends: libgnome2-0 but it is not installable
                 Recommends: libgnomevfs2-0 but it is not installable
                 Recommends: libgconf2-4 but it is not installable
                 Recommends: ttf-dejavu-extra but it is not installable
kiri
  • 28,986
Paul
With my experience with openjdk is not very good (I think it is even worse then Java itself) so I do not like java at all but if you want to install it I recommend you installing it with this guide
http://linuxg.net/how-to-install-oracle-java-jdk-678-on-ubuntu-13-04-12-10-12-04/
Levan
  • 11,118
