I plugged my I Phone into the USB port and don’t see the photos or music. I looked in search computer and online sources.
Thanks John
Thanks John
    This depends also on the type of iPhone, some details here (it's in French, but the images can be helpful).
Tested with an iPhone 5s.
~/Pictures); also, set the directory structure (or it will create its own sub-folders down to month and day by default, could be cumbersome; to only create folders for years, set Custom-Patern: %Y, for month-year select %m-%Y); after that importing will start, it takes some time;
at the end you will be asked if you want to delete from the iphone the imported pictures - be careful there!
the imported pictures will be remembered as part of the library once copied and will not be imported/copied next time even if you have deleted/moved them from your computer; to copy/import them again, go to Libray-Missing files, wait for search, then select the ones that you want to import again, right-click and remove, then restart the whole process to import.
(I will try to post on importing audio as soon as possible.)
If you want to see photos and videos displayed on your computer from your iphone you need itunes. Unfortunately itunes isnt available for linux. You can use Wine to fix this problem. Here is a tutorial http://freshtutorial.com/install-itunes-ubuntu-linux/
