When I resume my computer from suspend it doesn't want to connect to any wireless connection. It looks like it is connecting, but after a while it asks me to retype a password for wireless connection. It connect after I restart it.
I am using Toshiba Satellite A210 and Ubuntu 10.10 (I have the same problem with 10.04 and 11.04 beta2.
14:00.0 Ethernet controller: Atheros Communications Inc. AR5001 Wireless Network Adapter (rev 01)
Subsystem: Askey Computer Corp. Device 7128
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at cfcf0000 (64-bit, non-prefetchable) [size=64K]
Capabilities: <access denied>
Kernel driver in use: ath5k
Kernel modules: ath5k
Should I file a bug?
Lekensteyn
  • 178,446
lapor
  • 132
It doesn't help fix the bug, but here's a workaround.
  1. Use lsmod to find out which wireless driver you're running.
  2. Reproduce the problem.
  3. Kill the module (sudo rmmod [your driver]).
4 Reinsert the module (sudo modprobe [your driver]).
If wireless begins working again, you can create scripts in /etc/pm to do this each time you suspend and resume. It'll add a couple of seconds to reconnecting on resume, but that's all.
It's a common problem with some hardware combinations in linux, that some features will not properly be re-initialized after resuming from a suspended state. This goes for wireless functionality, graphics functionality and more, and can vary greatly depending on your hardware configuration.
If you can reproduce it properly, you should file a bug upstream to get it fixed - it is likely that this is a bug in the drivers causing your hardware to not be reinitialized properly when resuming from sleep.
Please don't take this as a confirmation that this is a bug, as there are more variables in play here, but filing a bug report can help you get it resolved either very soon or in a future release.
Though I'm sure our situation is not exactly the same, but I faced similar issue with my netbook, and the sound (& brutal) workaround was to upgrade to Ubuntu 11.10. See detail here. HTH.
IsaacS
  • 1,106
