I am quite new to Ubuntu and I see there are many folders in the root directory (/etc, /usr, /opt etc.). I would like to know if there is a standard folder where I should install java, eclipse and any other tar.gz files that are intended for unpacking and then compiling generally?
In general you do -not- install software using tar.gz files. These files are containers that hold software (that might contain software to install but normally you get is all done and ready for you to use). You use either Ubuntu software center or debian installer files to install software.
- Eclipse: https://askubuntu.com/a/118377/15811
- Java: https://launchpad.net/~webupd8team/+archive/java
So there should not be a need to use tar files for these 2 pieces of software.
But if you still want to continue with this: for these types of installations the advised location to extract tar.gz files is /opt/. The Filesystem Hierarchy Standard says:
/opt : Add-on application software packages
Purpose: /opt is reserved for the installation of add-on application software packages.
Personally, I will opt for... /opt.
/opt - This directory is reserved for all the software and add-on packages that are not part of the default installation.
More about: http://www.tldp.org/LDP/Linux-Filesystem-Hierarchy/html/opt.html.
- 174,089
- 51
- 332
- 407
