23
I see there are some nice apps being developed for Ubuntu touch and that some of them support larger screens. Now, I would like to run some of these apps on my desktop? Is this possible at the moment? If so, how could it be done?
I see that one can install the core apps, but I haven't found any instruction on installing click packages.
metakermit
  • 2,650
It's all done with the help of a PPA. All you have to do is to open a terminal and run the following command (you will need to be root):
sudo add-apt-repository ppa:ubuntu-touch-coreapps-drivers/daily
sudo apt-get update
sudo apt-get install touch-coreapps
When the installation finishes, you can find the application in Unity Dash. According to Alan Pope, the apps have been tested on Ubuntu 13.10 and Ubuntu 14.04.
Source: http://linux.softpedia.com/blog/How-to-Test-and-Use-Ubuntu-Touch-Core-Apps-on-the-Ubuntu-Desktop-433742.shtml
There is experimental emulator for ubuntu 14.04, when someone have it it can be installed from repositories:
sudo apt-get update
sudo apt-get install android-emulator
cp -r /usr/share/android/emulator/ ~/
cd ~/emulator/
./build-emulator-sdcard.sh
./run-emulator.sh
For other cases I recommend: https://wiki.ubuntu.com/Touch/Emulator
Hope it helps :)
pgr
  • 482
