On Ubuntu 12.10 when trying
sudo apt-get install mono-complete
to install mono, I get:
enter codReading package lists... Done
Building dependency tree
mono-complete : Depends: mono-devel (= 2.10.8.1-5ubuntu1) but it is not going to be installed
Depends: libmono-cil-dev (= 2.10.8.1-5ubuntu1) but it is not going to be installed
I tried removing mono-devel and libmono-cil-dev but they are not installed.
I've tried
sudo apt-get clean && apt-get update && apt-get upgrade
but it does not help.
dpkg --get-selections | grep hold
does not give any results, so it seems that no packages are actually held.
I've also tried
dpkg --configure -a
and
apt-get install -f
neither of which helped either.
Strangely though, I do have mono installed in /usr/bin/mono. The way that I got into this mess was that I tried to get the latest versions by following the directions here: http://www.meebey.net/posts/mono_3.0_preview_debian_ubuntu_packages/. apt-get was complaining about held packages at which point I did
sudo apt-get dist-upgrade
I don't know if that was the cause of my current problems. Anyway, after it continued to complain about packages being held, I removed that experimental mono deb source from my sources and removed mono-complete, and ran apt-get clean, update, and upgrade, to get back the blank slate. At that point, I tried to install mono-complete from a blank slate, and arrived to my current situation.
EDIT:
$ apt-cache policy mono-devel libmono-cil-dev
mono-devel:
Installed: (none)
Candidate: 2.10.8.1-5ubuntu1
Version table:
2.10.8.1-5ubuntu1 0
500 http://us.archive.ubuntu.com/ubuntu/ quantal/main i386 Packages
100 /var/lib/dpkg/status
libmono-cil-dev:
Installed: (none)
Version table:
2.10.8.1-5ubuntu1 0
@meebey of the linked experimental page recommends apt-get remove cli-common for a full mono removal which outputs this:
mono-xsp4 : Depends: mono-xsp4-base (= 2.10-2.1) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
RESOLVED I resolved this issue by adding the experimental ppa back and removed mono-complete and cli-common. Then I removed the experimental ppa again which got me back to a blank slate. For that reason I don't consider this a duplicate issue, but it doesn't matter.
