I have an AMD quad (A10) desktop, which has the following output from sensors:
$ sensors
f71808a-isa-0600
Adapter: ISA adapter
+3.3V:        +3.28 V
in1:          +0.00 V
in2:          +0.00 V
in3:          +0.00 V
3VSB:         +3.28 V
Vbat:         +3.46 V
fan1:         888 RPM
fan2:         991 RPM
fan3:           0 RPM  ALARM
temp1:       +231.0°C  (high = +85.0°C, hyst = +81.0°C)
                       (crit = +100.0°C, hyst = +96.0°C)  sensor = thermistor
temp2:        +35.0°C  (high = +85.0°C, hyst = +81.0°C)
                       (crit = +100.0°C, hyst = +96.0°C)  sensor = transistor
k10temp-pci-00c3
Adapter: PCI adapter
temp1:        +31.1°C  (high = +70.0°C)
                       (crit = +70.0°C, hyst = +69.0°C)
That temp1 reading is so high it looks wrong. It has been like that for a while, and the computer still works. Thoughts?
Oli
  • 299,380
sorak
  • 163
Things will start to melt when you go over 140°C. Things both in and around the CPU. 231°C is actually beyond the ignition temperature of a lot of plastic components that may be in your computer. That's a bad situation.
Given your desktop hasn't reduced itself to a flaming puddle (yet) I'm going to say this is almost certainly a bug in lm-sensors or the I²C driver.
You're not the only person to have run into their f71808a-isa-0600 I²C chip reporting exactly 231.0°C, here's another. They were having stability issues and found that disabling ACPI helped.
If you aren't experiencing any actual issues (and there isn't a dead fan) I'd just leave it but you may get value from reporting this as a bug. I'm not exactly sure who's responsible here. Start with the lm-sensors developers and see if you get kicked up to the kernel developers.
Oli
  • 299,380
