Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x344916fc
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 1945391103 972694528 83 Linux
/dev/sda2 1945393150 1953523711 4065281 5 Extended
Partition 2 does not start on physical sector boundary.
/dev/sda5 1945393152 1953523711 4065280 82 Linux swap / Solaris
shivam@shivam-Inspiron-5521:~$
- 15,174
This is an answer I wrote for someone else but it will help you for certain so I am copying it here.
Hello It would be easiest to just start from the beginning so lets do that, okay?
First, boot to your USB or DVD and let Ubuntu start a live session. You will see an icon on the desktop that says Install Ubuntu on your desktop. Launch (click on) it.
When you get to the screen where it asks you if you want to replace an existing install or install next to it or Something Else, choose Something Else.
Now you will see a screen that will let you see the hard drive you want to install to. Make sure you choose the correct drive you want to install ubuntu on! On that screen you will need to first delete any existing partitions so you can start fresh.
Start at the bottom of the listed partitions and right click on each one and choose Delete. After you have done this to all the partitions, click on Apply.
When you have deleted everything your drive will show as completely unallocated space! Sometimes some partitions cannot be deleted right away so delete all you can at first and click Apply, then start over from the bottom until they are all deleted.
Now you want to create the necessary partitions for you to install Ubuntu.
Create the following partitions:
a boot partition
/bootand give it 250 MB of space, chooseext4for the format.a root partition
/rootand give it 15000 MB of space andext4formata swap partition
/swapand give it 4096 MB of space (it will format to swap)a home partition
/homeand give it the rest of the space and format it toext4.Now just finish the install and it will run beautifully.
