99
What is the command line that displays file informations (or properties), such as in GUI method Display properties in GNOME?
Display properties GNOME
I know that ls -l shows properties; but how to display the same informations?
For example, instead of
rw-rw-r--
we have such GUI rendering:
abdennour@estifeda: $wishedCmd myFile
  Permissions :
    Owner Access: Read & write
    Group Access :Read & Write
    Others Access: Read only
Screenshot of permissions dialogue
kos
  • 41,268
10 Answers10
170
Use the stat command to know the details of the file. If file name is file_name, use
stat file_name
muru
  • 207,228
Arun. K. P
  • 1,801
43
There is no dedicated command for this. For meta information like time, size and access rights, use
ls -l path-to-file
You might also be interested in what kind of file it is, file path-to-file will help you with that.
Jens Erat
  • 5,131
  • 33
  • 37
33
Have you tried file?
For example:
SirCharlo
  • 40,096
19
Something like
#!/bin/bash
print_perm() {
  case "$1" in
    0) printf "NO PERMISSIONS";;
    1) printf "Execute only";;
    2) printf "Write only";;
    3) printf "Write & execute";;
    4) printf "Read only";;
    5) printf "Read & execute";;
    6) printf "Read & write";;
    7) printf "Read & write & execute";;
  esac
[[ ! -e $1 ]] &&  echo "$0 <file or dir>" 2>&1 && exit 1
perm=$(stat -c%a "$1")
user=${perm:0:1}
group=${perm:1:1}
global=${perm:2:1}
echo "Permissions :"
printf "\tOwner Access: $(print_perm $user)\n"
printf "\tGroup Access: $(print_perm $group)\n"
printf "\tOthers Access: $(print_perm $global)\n"
Output
# rwxr-x--- foo*
> ./abovescript foo
Permissions :
    Owner Access: Read & write & execute
    Group Access: Read & execute
    Others Access: NO PERMISSIONS
Danatela
  • 13,384
13
ls -lh filename
for human readable version
A.B.
  • 92,125
Ross Jones
  • 231
Display the attributes of the files in the current directory:
lsattr
List the attributes of files in a particular path:
lsattr path
List file attributes recursively in the current and subsequent directories:
lsattr -R
Show attributes of all the files in the current directory, including hidden ones:
lsattr -a
Display attributes of directories in the current directory:
lsattr -d
Bou Said
  • 121
You can use ls command to list files and their properties by adding the -l option. Example:
$ls -l filename
As described in the Linux Pocket Guide by Daniel J. Barrett you can list extended attributes of files and directories with:
lsattr file_name
You can try the following script:
set filepath "$HOME/.bashrc"
set fileuri $(echo $filepath | python -c "import sys, pathlib; print(pathlib.Path(input()).resolve().as_uri())")
dbus-send --session --print-reply --dest=org.freedesktop.FileManager1 /org/freedesktop/FileManager1 org.freedesktop.FileManager1.ShowItemProperties array:string:"$fileuri" string:""
P.S. If you do not convert file path to file uri then path like $HOME/Desktop/directory with spaces and ümläuts.txt will not work.
Use
ls -l filename
(use small L)
Eric Carvalho
  • 55,453
