How to remove all the lines from the text file containing the words "cat" and "rat"?
grep approach
To create a copy of the file without lines matching "cat" or "rat", one can use grep in reverse (-v) and with the whole-word option (-w).
grep -vwE "(cat|rat)" sourcefile > destinationfile
The whole-word option makes sure it won't match cats or grateful for example. Output redirection of your shell is used (>) to write it to a new file. We need the -E option to enable the extended regular expressions for the (one|other) syntax.
sed approach
Alternatively, to remove the lines in-place one can use sed -i:
sed -i "/\b\(cat\|rat\)\b/d" filename
The \b sets word boundaries and the d operation deletes the line matching the expression between the forward slashes. cat and rat are both being matched by the (one|other) syntax we apparently need to escape with backslashes.
Tip: use sed without the -i operator to test the output of the command before overwriting the file.
To test in terminal only, use:
sed '/[cr]at/d' file_name
To really remove those lines from the file, use:
sed -i '/[cr]at/d' file_name
- 174,089
- 51
- 332
- 407
Try using ex command (part of Vi/Vim):
ex +"g/[cr]at/d" -scwq file.txt
The above has the advantage over other tools such as sed due to its non-standard FreeBSD -i (in-place) extension and may not be available on other operating systems. Secondly sed is a Stream EDitor, not a file editor.
- 10,944
Delete lines from all files that match the match
grep -rl 'text_to_search' . | xargs sed -i '/text_to_search/d'
- 121
Using awk to exclude lines containing specific words:
$ awk '!/\<(cat|rat)\>/{print $0}' ./input.txt
awk syntax:
!/regex/Only print lines that do not match regex.|Alternation operator, used to specify alternatives.(...)Grouping, for example grouping alternation operators.\<Matches the empty string at the beginning of a word.\>Matches the empty string at the end of a word.{...}Action statement.
cat logs.txt | grep 'your regex' > logs_regex.txt
This will create a new file logs_regex.txt which is a copy of your file logs.txt with only the lines containing your regex
- 101
Consider if you have file with file_name and you want to search for mouse but on the same time few rows from mouse having other words like cat and rat and you don't want to see those in your output, so the one way to do it is -
grep -r mouse file_name | grep -vE "(cat|rat)"
- 207,228
- 321
portable shell way
Works in /bin/sh, which is dash on Ubuntu, as well as ksh, and bash. Slightly awkward that you have to write multiple test cases for each word in case statement but portable. Works with cases where word appears alone on the line, in the beginning, end of the line, or middle of the line, and ignores where it might be part of another word.
#!/bin/sh
line_handler(){
# $1 is line read, prints to stdout
case "$1" in
cat|cat\ *|*\ cat\ *|*\ cat) true;; # do nothing if cat or rat in line
rat|rat\ *|*\ rat\ *|*\ rat) true;;
*) printf "%s\n" "$1"
esac
readlines(){
# $1 is input file, the rest is words we want to remove
inputfile="$1"
shift
while IFS= read -r line;
do
line_handler "$line" "$@"
done < "$inputfile"
[ -n "$line" ] && line_handler "$line"
readlines "$@"
And this is how it works:
$ cat input.txt
the big big fat cat
the cat who likes milk
jumped over gray rat
concat
this is catchy
rat
rational
irrational
$ ./dellines.sh input.txt
concat
this is catchy
rational
irrational
- 107,582
