When I am inside folder in nautilus I want to be able to open that folder in terminal. This can be done with nautilus-open-terminal package described in Where is 'open in terminal'?
However, I use tilda as my default terminal, because it is drop-down which makes it easy to use.
So my question is - how do I use "Open in terminal" option to open new tab in tilda instead of default terminal?
This question is about opening terminal from folder, not about opening folder from terminal. Opening folder from terminal is easy - you just need to type nautilus . or xdg-open.
EDIT: Since nothing else worked, I solved this problem by writing nautilus script that outputs current location to text file and then another script (executed from my chosen terminal) that reads that file and uses cd to change directory.
Rafal
  • 1,837
You could try this:
sudo update-alternatives --config x-terminal-emulator
Have you tried this?
https://askubuntu.com/a/76747/164073
thnee
  • 214
