Hello All I am Having a problem in installing tor in ubuntu....when i start adding tor repository to my system and write the command
gpg --keyserver keys.gnupg.net --recv 886DDD89
then a error comes which is
gpg: Invalid option "--keyserver.ubuntu.com"
hailendra@hailendra-Ideapad-Z570:~$ gpg --keyserver keys.ubuntu.com --recv 886DDD89
gpg: requesting key 886DDD89 from hkp server keys.ubuntu.com
gpgkeys: key 886DDD89 not found on keyserver
gpg: no valid OpenPGP data found.
gpg: Total number processed: 0
can any one help me what to do?
qbi
  • 19,515
In order to be able to install from a secured repository you will need to add their public key to apt.
You should have received an information on where to get the public key from the makers of the repository. Download this key and save it on your drive.
The we can add this key with
sudo apt-key add </path/name_of_downloaded_key_file>
Takkat
  • 144,580
The keyserver keys.ubuntu.com seems not to be active at the moment. You can however use keys.gnupg.net:
gpg --export A3C4F0F979CAA22CDBA8F512EE8CBC9E886DDD89 | sudo apt-key add -
qbi
  • 19,515
-1
try gpg --keyserver keyserver.ubuntu.com --recv 886DDD89 this should work
try directly copy and execute command from line above, in your question you have mistake in input string gpg: Invalid option "--keyserver.ubuntu.com"
and you should use keyserver.ubuntu.com instead of keys.ubuntu.com
when key is received export it using this: `gpg --export A3C4F0F979CAA22CDBA8F512EE8CBC9E886DDD89 | sudo apt-key add -
If this doesn't work please post output of this command: gpg --keyserver keyserver.ubuntu.net --search-keys 886DDD89
ForceUser
  • 101
