I just completed the installation process for Ubuntu 13.04, and when it completed it said it needed to restart. After restarting, Windows 8 booted up, with no option for Ubuntu whatsoever.
qmlowery
  • 115
do you remember where you put the bootloader grub? There were the two possibilities to put it either to the mbr (e.g. /dev/sda) => in this case your ubuntu should have booted right. Or to put it to the root-partition (e.g. /dev/sda2). In this case you would have reainstall it to mbr, e.g. via "grub rescue disk"
opiwahn
Try to remember if you have either installed grub that is broken, or that you didn't have grub, try to boot into a live CD and install boot repair via terminal.
Commands are following:
sudo add-apt-repository ppa:yannubuntu/boot-repair && sudo apt-get update
sudo apt-get install -y boot-repair && (boot-repair &)
Now you should be fine, it automatically detects your operating systems and you can boot in Ubuntu also!
Joren
  • 5,074
Donut20
  • 26
When I installed Ubuntu, it didnt change the default boot option at all.
Startup into UEFI/BIOS by holding f2 button, then select Ubuntu as the default boot option. then, upon starting, you should see the Ubuntu boot menu, where you can choose what to boot.
If you dont have the Ubuntu boot option, or your Windows menu item doesnt work, then you could try looking at this thread:
Ubuntu 13.04 install gone wrong: no GUI in ubuntu and CANNOT boot into Windows 8
user195059
  • 119
I am not sure, because I don't have windows 8 but on this page they mention you should disable FastStartup in windows 8. I can imagine this could cause grub not to be loaded. please let me know if this helps, I see a similar question pop up more often and I would like to know if I should suggest this answer.
Wouter
  • 713
  • 17
