I am trying to write a simple qml application being a n2n frontend of the client and following the tutorial. This application is first intended for the desktop, but if it can also be used as a phone application for Ubuntu Touch, even better.
You can see the code hereunder, but since I am not really a developer, I have basic questions:
- How can I execute a shell command in qml (the n2n programme is run in the terminal with the "edge" command + few parameters).
- How can I pass variable in this shell command to be executed?
- How to store the parameters in a configfile for the next time?
Thanks in advance for your help!
The code:
import QtQuick 2.0
import Ubuntu.Components 0.1
import "components"
import Ubuntu.Components.ListItems 0.1
import Ubuntu.Components.Popups 0.1
\brief MainView with a Label and Button elements.
MainView {
// objectName for functional testing purposes (autopilot-qt5)
objectName: "mainView"
// Note! applicationName needs to match the "name" field of the click manifest
applicationName: "com.ubuntu.developer.No Launchpad user ID configured..n2nedge"
This property enables the application to change orientation
when the device is rotated. The default is false.
//automaticOrientation: true
width: units.gu(30)
height: units.gu(50)
property real margins: units.gu(2)
property real buttonWidth: units.gu(9)
Page {
title: i18n.tr("n2n edge")
Column {
anchors {
fill:parent
margins: root.margins
spacing: units.gu(1)
Row {
TextField {
placeholderText: "Password"
echoMode: TextInput.normal
Row {
TextField {
placeholderText: "Node IP"
Row {
TextField {
placeholderText: "Node port"
Row {
TextField {
placeholderText: "Network name"
Row {
TextField {
placeholderText: "client IP"
Row {
Button {
text: i18n.tr("Validate")
width: units.gu(12)
onClicked: {
cmdForm.update();
Row {
TextField {
placeholderText: "sudo edge -a ClientIP -c NetworkName -k pwdForm -l NodeIP:NodePort"
