I'm stumped.
On my system, software-center was crashing within 2 seconds of execution. I tried to resolve the issue by running:
sudo apt-get remove --purge software-center
sudo apt-get install software-center
Unfortunately, the install fails. I get this error:
sudo apt-get install software-centerReading package lists... Done
Building dependency tree
 software-center : Depends: python-gi (>= 3.4.0-1ubuntu0.1) but it is not going to be installed
                   Depends: python-gi-cairo but it is not going to be installed
                   Depends: python-aptdaemon (>= 0.40) but it is not going to be installed
                   Depends: python-aptdaemon.gtk3widgets but it is not going to be installed
                   Depends: oneconf (>= 0.2.6) but it is not going to be installed
                   Depends: python-oneconf (>= 0.3) but it is not going to be installed or
                            oneconf (< 0.3) but it is not going to be installed
                   Recommends: sessioninstaller but it is not going to be installed
In desperation, I tried apt-get build-deps, but this also failed.
sudo apt-get build-dep python-gi python-gi-cairo python-aptdaemon.gtk3widgets oneconf python-oneconf oneconf sessioninstaller
Picking 'pygobject' as source package instead of 'python-gi'
 libcairo2-dev : Depends: libfontconfig1-dev (>= 2.2.95) but it is not going to be installed
 libglib2.0-dev : Depends: libglib2.0-0 (= 2.36.0-1ubuntu2) but 2.36.3-0ubuntu1~raring1 is to be installed
                  Depends: libglib2.0-bin (= 2.36.0-1ubuntu2)
E: Build-dependencies for python-gi could not be satisfied.
Any ideas?
MattY
  • 401
Try to install all dependencies first. Seems your dependencies have dependencies as well. Have you tried sudo apt-get install -f?
Chester
  • 1,098
  • 15
