I used the Vagrant image for Ubuntu 13.04 64-bit from http://cloud-images.ubuntu.com/vagrant/raring/current/raring-server-cloudimg-amd64-vagrant-disk1.box to create a new virtual machine on my MacBook (10.8) and can successfully ssh to it. The problem is that though VirtualBox shows the size of the virtual machine's hard drive to be 40 Gb (dynamic), df-h command executed within the virtual machine shows that /dev/sda1 has only 4Gb, which is not enough for my needs:
/dev/sda1 4.0G 970M 2.8G 26% /
How can I ensure that my the Vagrant Ubuntu VM has enough space (e.g. 20Gb) on its sda1 partition?
silentser
  • 101
Those are automatically built Vagrant Ubuntu Cloud Images, we have no control over how they were built.
You either build your own vagrant box or 1. resize existing virtual HDD 2. Attach additional virtual HDDs, create file systems and mount it (e.g. /ops and install new stuff in this directory).
Personally I think option 2 is easier.
If you want to go with option 1, you'll have to convert the existing virtual HDD (VMDK) to VDI, because VBoxManage modifyhd only works with native VDI image. However, vagrant base boxes are basically exported OVF/OVA using VMDK format.
See VirtualBox Docs
The --resize x option (where x is the desired new total space in megabytes) allows you to change the capacity of an existing image; this adjusts the logical size of a virtual disk without affecting the physical size much.[37] This currently works only for VDI and VHD formats, and only for the dynamically allocated variants, and can only be used to expand (not shrink) the capacity.
Steps to increase the capacity of disk for Vagrant Base Box
  1. To be able to resize the HDD, you'll have to covert it to VDI first, e.g. VBoxManage clonehd in.vmdk out.vdi --format VDI and then re-attached it (using the GUI is easy).
  2. Resize it using VBoxManage modifyhd box.vdi --resize 15360 which increase the capacity to 15GB.
  3. However this only changes the drive capacity, you will have to grow the file system for the guest afterwards. For example, use resize2fs -p -F DEVICE for ext4.
Refer to the answer here for more details => How can I increase disk size on a Vagrant VM?
Terry Wang
  • 10,185
It seems there is an issue with this specific Vagrant image. I've used a different one (https://dl.dropboxusercontent.com/u/547671/thinkstack-raring64.box) and there the problem does not occur.
silentser
  • 101
