What I am trying to accomplish is extremely close to this, with one twist. I want the second "nic" to be a second ip address (I guess sometimes called a virtual nic), added to the same physical nic (on the same subnet, and able to get to the gateway if I specifically send a packet over this new nic). I know you will probably ask why the h*ll I need to do that, and as you might guess its a long, complicated answer, but the bottom line is I need:
  • Two unique addresses that can get to the internet when I bind to them specifically
  • Those interfaces be on the same subnet for ease of the remainder of the network config
If it helps, the second interface need only "behave" when I bind to it and send packets out of it (or packets specifically arrive to it). That is, I don't need any other routing rules than that.
Now, I tried the most obvious which is to modify the answer above just changing eth1 to eth0:1, however that did not work for me, resulting in RTNETLINK answers: File exists and the virtual nic not actually functioning when I bound to it (for example, with a simple test of wget --bind-address.
I feel like that solution is very close though, it just needs a little something more - please help!
You can also do it this way. This method is better for newer ubuntu systems.
auto eth0
iface eth0 inet static
    address 192.168.1.50
    netmask 255.255.255.0
    broadcast 192.168.255
    gateway 192.168.1.1
         # the "up" lines are executed verbatim when the interface is brought up
    up ip addr add 192.168.1.2 brd 192.168.1.255 dev eth0 label eth0:0
    up ip addr add 192.168.1.3 brd 192.168.1.255 dev eth0 label eth0:1
