sometimes the xfce4-power-manager does not show up in the panel and it`s not working at all, and sometimes is working.
when it`s not working I have 2 solutions:
    • log out, and log in.
    • start system monitor and kill xfce4-power-manager, then start terminal and type:
    xfce4-power-manager --no-daemon
usually I use second solution, but to simplify the process I tried to write a shell script that restarts the xfce4-power-manager, with no success.
I cannot shut down the xfce4-power-manager from terminal.
xfce4-power-manager --restart
-is not working
xfce4-power-manager --quit
-is not working
I tried:
#!/bin/bash
PID=`pidof xfce4-power-manager`
kill $PID
-is not working.
If I type:
xfce4-power-manager --customize
-an error window appears with:
Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
in the system monitor at Waiting Chanel says: futex_wait_queue_me.
Thank you
xfce4-power-manager not started, applet not visible
Delete > Desktop configuration file:
/etc/xdg/autostart/xfce4-power-manager.desktop
Settings Manager / Session and Startup / Startup Applications
Item disabled:
Energy Management (power Management Xfce environment)
New item enabled with new command:
Mame: Xfce Power Manager (For example-Your name)
Description: Power manager startup
Command: xfce4-power-manager --no-daemon
http://ubuntuset.url.ph/power_manager.html
Pygman
