11
I am working with meteor.js and I need to increase the value of /proc/sys/fs/inotify/max_user_watches to solve my problem (here is a description of problem and solution).
But I can not do it:
➜  ~  sudo echo 10000 > /proc/sys/fs/inotify/max_user_watches
zsh: permission denied: /proc/sys/fs/inotify/max_user_watches
How can I change this value ?
ceth
  • 913
Just become root by running
sudo su
And then
ph0t0nix
  • 1,397
Qasim
  • 22,162
14
with your command, only the part on the left is run as root. you're running echo as root but not the file writing on the right. You could use this to echo as a normal user and write to the file as root.
echo 10000 | sudo tee /proc/sys/fs/inotify/max_user_watches
tee will write to standard out (your terminal) and to a file, so you run tee as root to write to a root-owned file.
Joe A
  • 299
For permanent configuration:
echo 'fs.inotify.max_user_watches = 1524288' | sudo tee /etc/sysctl.d/99-whatever.conf
sudo sysctl -p --system
then restart the application you've been using.
source: https://confluence.jetbrains.com/display/IDEADEV/Inotify+Watches+Limit and this: https://github.com/guard/listen/wiki/Increasing-the-amount-of-inotify-watchers
Kokizzu
  • 518
