35
Are repository updates secure?
As a bear of little brain from the developer side, I cannot understand why the repository list is http://security.ubuntu.com and the other http(unsecured) sites listed in /etc/apt/sources.list. Without a certificate chain match this appears as "ask any responder for a list of packages to update" instead of "ask the ubuntu.com site..."
Can any network choose to spoof the update sites, and is this a common practice to provide a locally cached and vetted copy?
blade19899
  • 26,994
Charles Merriam
  • 471
Update 2022: Repository hosts/mirrors tend to support HTTPS now, so you may as well use it to give additional assurance on top of what APT provides. Read below for an explanation of why HTTPS alone wouldn't be enough to protect you, and why APT adds its own cryptographic security.
In short, there is security without HTTPS, because all the packages are cryptographically signed and APT verifies the signatures.
The APT system is a secure packaging solution in which packages are signed with keys known only to Ubuntu and APT verifies the signatures against the package using public keys in APT's keyring on your system. This effectively provides end to end assurance that the package is unmodified by anyone outside of Ubuntu regardless of whether you obtained it from an official Ubuntu server or some mirror somewhere.
Ubuntu's repository system was built (as part of Debian) in a way so you don't have to trust the mirror you use, just that they didn't modify the package since it was signed internally by the distribution. This allows for the repository to be decentralized and for any volunteer to set up a mirror.
So, for example, you could use example.com as a mirror - if you were to use HTTPS and verify that you really are talking to example.com, it doesn't tell you anything useful, such as whether that mirror is approved by your distribution (Ubuntu) or whether that mirror modifies the packages after it gets them from Ubuntu to add viruses, it just tells you that you're talking to example.com. But APT's built in signature verification does provide those assurances.
A technical explanation of how this works is available from Ubuntu (and from Debian which uses the same system).
APT does work over HTTPS and you can use HTTPS in an APT sources entry to apply another level of assurance to your connection (if the repository you're using supports it). This can act as an additional safeguard on top of APT's, especially now that past concerns about additional overhead imposed by HTTPS connections are less relevant.
Arguments for using HTTPS:
Not using HTTPS can be a privacy concern, because eavesdroppers could see what files you are downloading, though privacy has not historically been considered to be concern in this case as they are publicly available files, and APT's verification can still detect modification. Nonetheless HTTPS could be used to make it harder for attackers to see what you are installing.
Another assurance that APT's signing mechanism doesn't provide is that the packages you are receiving are the latest available version. As a mitigation to this, the signed release file includes a "Valid-Until" date field after which the files it references should be considered out of date. It would be plausible for a man-in-the-middle or nefarious mirror to substitute an archive with an unmodified earlier version of the archive within this Valid-Until date and delay an update to a package for this time window. But they can't make any arbitrary modifications to packages nor could they go back in time past that point.
Another reason you may consider using HTTPS is to guard against flaws in APT's own signing and verification. Flaws in this have been discovered, and fixed, in the past.
thomasrutter
  • 37,804
32
The top rated answer here is clearly outdated. Since then, there has been 2 serious remote code execution exploits found in apt because of buggy package verification. Security bulletins here and here.
This is much worse than the concerns about privacy/information leakage and stale package version; this enables arbitrary code execution as root, complete security failure. And the thing is: These attacks would have been prevented if https was used instead of http.
This proves that the defence in depth principle applies here as much as anywhere else. The many claims floating around that https provides no or minimal security benefit in the context of apt is simply incorrect, as has been shown by these exploits.
The question then becomes if the security benefit of https is worth the cost in terms of caching, increased overhead etc. I can't answer that, but at the very least I think Ubuntu/Canonical/Launchpad should provide optional https endpoints for their repositories.
Important supplement:in fact, as upgrade and initial installation download online, it takes a lot of traffic, and the source of these traffic, that is, binary and text code streams, is reproducible. So there are a large number of gateways and cache devices on the Internet for it. A considerable number of ISPs had set up cache based on the http protocol in order to save the export bandwidth, and the https protocol cannot exist as a transparent cache.
Another reason is that the http-based mirroring program is much simpler, there is no need to verify the tls-ssl certificate, and no need to worry about certificate invalidation or web server configuration problems too.
Not too long ago, about 20 years, at beginning of Internet, https and Internet traffic were still very expensive gameplays. Therefore, http also included the ftp protocol, which is close to being obsolete, as the main way of delivering installation and update for software packages distribution online.
Similarly, Microsoft Windows and Office are also upgraded using http. You can observe that it is usually not the installation package downloaded from the Microsoft's server, but your ISP's self-built cache server.
J.Z
  • 131
