So telnet actually is working, I mean telnet localhost 25 is connecting; but telnet localhost or telnet localhost 9000 got such result:
Trying 127.0.0.1...
telnet: Unable to connect to remote host: Connection refused
nmap results:
$ nmap localhost
Starting Nmap 6.00 ( http://nmap.org ) at 2013-10-03 00:54 MSK
Nmap scan report for localhost (127.0.0.1)
Host is up (0.00030s latency).
rDNS record for 127.0.0.1: localhost.localdomain
Not shown: 992 closed ports
PORT     STATE SERVICE
22/tcp   open  ssh
25/tcp   open  smtp
80/tcp   open  http
587/tcp  open  submission
631/tcp  open  ipp
3306/tcp open  mysql
5432/tcp open  postgresql
6566/tcp open  sane-port
nmap on 9000 port:
$ nmap -p 9000 localhost
Starting Nmap 6.00 ( http://nmap.org ) at 2013-10-03 00:55 MSK
Host is up (0.000040s latency).
PORT     STATE  SERVICE
9000/tcp closed cslistener
So the question is how to open necessary port, Im using Ubuntu 13.04; tried to disable ufw, tried to play with iptables; nothing helped. Dunno even what to do...
I need 9000 port for hadoop; I cant access fs without opened 9000 port
Braiam
  • 69,112
DaunnC
  • 153
The reason for connection refused is simple - the port 9000 is NOT being used (not open).
Use the command => lsof -i :9000 to see what app is using the port. If the result is empty (return value 1) then it is not open.
You can even test further with netcat.
List on port 9000 in terminal session 1
nc -l -p 9000
In another session, connect to it
$ lsof -i :9000
COMMAND   PID  USER   FD   TYPE  DEVICE SIZE/OFF NODE NAME
nc      12679 terry    3u  IPv4 7518676      0t0  TCP *:9000 (LISTEN)
$ nc -vz localhost 9000
Connection to localhost 9000 port [tcp/*] succeeded!
So you need to fix your hadoop settings and make sure all necessary daemons/services are started properly before you can connect to use HDFS.
NOTE: This is NOT telnet nor iptables issue, it's basically TCP/IP basics. Please change the question to sth like "connecting to port 9000 issue".
Update
i need 9000 port for hadoop; I can't access fs without opened 9000 port so base on the context my understanding is that HDFS's namenode is supposed to use port 9000. So check your Hadoop/HDFS configuration files and get the services started.
iptables is irrelevant at this stage because the port is NOT used at all.
You can run iptables -L -vn to make sure there is no rules in effected. You can flush the filter table INPUT chain to make sure sudo iptables -P INPUT ACCEPT && sudo iptables -F -t filter
Terry Wang
  • 10,185
If it helps anyone, I solved my similar problem by formatting the namenode again:
hdfs namenode -format
Louis M
  • 151
I had this same problem. At first, it worked fine with 'hdfs namenode -format', although just for one time. It happened that I used '/usr/hadoop-2.9.0/sbin/start-dfs.sh' (and stop-dfs.sh) to start Hadoop. Just when I began to use '/usr/hadoop-2.9.0/sbin/start-all.sh' (after had applied 'hdfs namenode -format') the 9000 port began to be used by Hadoop. "Stranger things!"
