20
When I try to run apt-get update I get the following error messages: I am using:
Distributor ID: Ubuntu
Description:    Ubuntu 11.04
Release:    11.04
Codename:   natty
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/natty-security/multiverse/binary-i386/Packages  404  Not Found [IP: 91.189.92.201 80]
E: Some index files failed to download. They have been ignored, or old ones used
I have tried few solutions:
  1. Like choose the best server from Ubuntu Software section : It was never able to select the best server as it gave error (Check your internet connection.) My internet is working fine and I am able to browse.
  2. sudo sed -i -e 's/archive.ubuntu.com\|security.ubuntu.com/old-releases.ubuntu.com/g' /etc/apt/sources.list
  3. sudo dpkg --configure -a
Nothing worked. I am not able to post the full error message as its not letting me post more than two links.
Braiam
  • 69,112
Amit
  • 303
Natty no longer supported or gets updates. You need to change from the archive.ubuntu.com to the old-releases.ubuntu.com server, which is the intention of the sed command you mentioned (I have not had chance to confirm if that works or not). Open and replace all entries in the following file:
sudo gedit /etc/apt/sources.list
Then after run the update and upgrade commands as you would normally.
NGRhodes
  • 9,680
