Previously, all of my disk partitions where called /dev/sda1, /dev/sda2, ... My network stopped working (couldn't ping out), and after a sudo ifdown eth0 and sudo ifup eth0, my desktop went away and my computer froze (Ubuntu 12.10, 32 bit - should have installed 64-bit, but too late to correct). After making a live boot CD, and mounting etc., I have now found that all my partitions are labelled /dev/sde1, /dev/sde2... I eventually got the system back through mounting the appropriate sdex's on /mnt/dev, /mnt/sys, /mnt/proc, etc., chroot, and update-grub, but I have no idea (and have not been able find using Google) any info on why names changed. Is anyone familiar with this? Thanks.
-Bi
Asked
Active
Viewed 357 times
Waldir Leoncio
- 1,925
bit_pusher
- 11
The internal disk identifiers aren't supposed to be stable in Linux. Therefore you should not rely on the names of /dev/sd?* to remain the same after reboot or after disconnecting and reconnecting a removable medium.
If you need to refer to a specific device in a script or configuration file, use device IDs, UUIDs, or file system labels as in /dev/disk/.
David Foerster
- 36,890
- 56
- 97
- 151
