In Ubuntu 13.04, whenever I decrease brightness, it still stays at its highest, and won't decrease. What's the fix?
Info
13.04, using Gnome Environment, but its Ubuntu 13.04. Dell Inspiron
Also, cannot get updates at ALL
"Failed to get repository information." Sudo apt-get update also gives errors at end.
Ninad
  • 386
Edit the grub configuration:
$gksu gedit /etc/default/grub
add:
GRUB_CMDLINE_LINUX="acpi_backlight=vendor"
after:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
then update the grub and restart:
$update-grub && reboot
I faced the same problem and did the following to resolve the issue. Firstly, do this...
  1. Open up the Terminal and type sudo gedit /etc/rc.local
  2. Then add this line before exit 0
    echo 980 > /sys/class/backlight/intel_backlight/brightness
  3. Now save the file. You can adjust value as you wish.
The above steps will hold the brightness on reboots. Next, see this answer given to my question regarding the same issue Brightness Controls Not Working on a Dell Inspiron N4010 Laptop.
