I installed sublime text 2 via apt-get as advised in the numerous answers in this question: How do I install Sublime Text 2/3?
I used the following commands to install:
sudo add-apt-repository ppa:webupd8team/sublime-text-2
sudo apt-get update
sudo apt-get install sublime-text
When I start it (using terminal command 'sublime' or the UNITY dock icon, I get the following error:
Unable to run package setup:
Traceback (most recent call last):
File "./PackageSetup.py", line 165, in upgrade
upgradePackage(pkg, pristinedir, datadir, backupdir)
File "./PackageSetup.py", line 158, in upgradePackage
os.path.join(backupdir, base), inhibitOverwrite)
File "./PackageSetup.py", line 113, in upgradeArchive
shutil.copy(src, dst)
File ".\shutil.py", line 88, in copy
File ".\shutil.py", line 53, in copyfile
IOError: [Errno 13] Keine Berechtigung: u'/home/noel/.config/sublime-text-2/Pristine Packages/Text.sublime-package'
"Keine Berechtigung" means "no permission", fyi. ;)
Before installing this via apt-get I had two failed installations (both times the program itself ran fine, but I couldn't save files. Either the error was "couldn't save" or "couldn't save, couldn't create tmp-file").
Can you please help me get this thing finally working? :/
I'm using 13.04, by the way.
EDIT: I now installed using the script kindly created by henriquemoody (https://gist.github.com/henriquemoody/3288681) and managed to get a working version of sublime running. This question could be considered as answered.
