Given a folder containing images in pdf-format (each of which has a name of the form NAME.pdf, with NAME being composed of several words separated by spaces),how do I batch convert the images to jpg-format and preserve their names in the form NAME.jpg ?
Using pdftoppm as indicated in How to convert a .pdf file into a folder of images? seems rather complicated, since it requires treating each image separately.
andrew.46
  • 39,359
You can use convert from imagemagick to convert a PDF into an image.
To install it, use the following command:
sudo apt-get install imagemagick
To convert all PDFs in a directory, go to that directory and run the following command:
for i in *.pdf; do convert "$i" "${i%.*}.jpg"; done
ImageMagick documentation | Bash string manipulation
binfalse
  • 889
