I recently moved from Microsoft WIndows 8 to Ubuntu 12.04. I have Dell Inspiron 3521 but the Wireless or wifi is not working. I tried through additional drivers but a message is alerted that Proprietary drivers are not available or suppoted. check var/log/jockey. Please Help me regarding this problem as I need much to solve this. Thanks.
Output for lspci is:
00:00.0 Host bridge: Intel Corporation Ivy Bridge DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Ivy Bridge Graphics Controller (rev 09)
00:14.0 USB controller: Intel Corporation Panther Point USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation Panther Point MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation Panther Point USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation Panther Point High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation Panther Point PCI Express Root Port 1 (rev c4)
00:1c.1 PCI bridge: Intel Corporation Panther Point PCI Express Root Port 2 (rev c4)
00:1d.0 USB controller: Intel Corporation Panther Point USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation Panther Point LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation Panther Point 6 port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation Panther Point SMBus Controller (rev 04)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 05)
02:00.0 Network controller: Broadcom Corporation Device 4365 (rev 01)
Output forsudo lshw -c network is:
*-network
       description: Ethernet interface
       product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:01:00.0
       logical name: eth0
       version: 05
       serial: e0:db:55:da:b4:2c
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl_nic/rtl8105e-1.fw ip=192.168.1.2 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:41 ioport:2000(size=256) memory:c0404000-c0404fff memory:c0400000-c0403fff
  *-network UNCLAIMED
       description: Network controller
       product: Broadcom Corporation
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:02:00.0
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: latency=0
       resources: memory:c0500000-c0507fff
Output for rfkill list all is:
1: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
Dan
  • 6,784
I have found something interesting for you , Ubuntu have developed their ISO for your Laptop which will consists of all drivers inside. I mean along with your Ubuntu you can have the drivers installed.
http://www.ubuntu.com/certification/hardware/201208-11539/
The Dell Inspiron 3521 portable has been awarded the status of Certified for Ubuntu. Please note that for pre-installed systems:
The system is available in some regions with a special image of Ubuntu pre-installed by the manufacturer. It takes advantage of the hardware features for this system and may include additional software. You should check when buying the system whether this is an option.
Standard images of Ubuntu may not work at all on the system or may not work well, though Canonical and computer manufacturers will try to certify the system with future standard releases of Ubuntu.
Yes you can check here that
http://www.ubuntu.com/certification/catalog/component/pci/8086:0887/
The ISO have drivers too.enter image description here
Raja G
  • 105,327
  • 107
  • 262
  • 331
I think will help you. I like to use WICD because it is a simple and easy to use network manager. Its a very good alternative to network manager in Ubuntu and it seems to always work when Network Manager doesn't. To install it just open up the terminal. Now download the latest NetworkManager, in case you need to reinstall it if WICD doesn't work
sudo apt-get install -d --reinstall network-manager network-manager-gnome
Then to install it
sudo apt-get install wicd-gtk
And now you need to uninstall NetworkManager:
sudo apt-get remove --purge network-manager-gnome network-manager
Now you can find WICD in your menu Start WICD, find the network you want to use and enter the information needed, password, encryption, etcetera and choose Automatically Connect to this network. You should be good to go!
WICD may also be available in Ubuntu Update Manager so you can look there first but it is important to uninstall Network Manager completely to prevent conflicts!!
Ronshere
  • 493
