85
I have a lot of images which have white borders around them. I would like to crop those borders all at once, preferably from command line. I believe that it can be done with ImageMagick, but I couldn't find suitable command.
I know that it can be done with Windows program named Irfanview with "Auto crop borders" option, but I am looking for Ubuntu-based and preferably command line based solution.
karel
  • 122,292
  • 133
  • 301
  • 332
Rafal
  • 1,837
ImageMagick Trim
The command line option trim used together with convert, or mogrify lets you trim borders of the same color as the corners of an image.
Usage:
The additional option -fuzz (which takes a percentage as an argument, e.g. -fuzz 10%) also removes colors near the corner colors.
Note: The -fuzz option must precede -trim because options' order matters for convert command to work as expected.
Use the option +repage to remove a canvas (if applicable).
ImageMagick Batch Trim (find)
Above command for ImageMagick Trim can also be used to batch process images combined with the find command:
find ./ -name "pattern" -exec convert {} -trim outputfolder/{} \;
The above command will trim all images that fit the pattern part of the command and save them in a new folder named outputfolder.
Assuming that images are PNGs, then command will look like this:
find ./ -name "*.png" -exec convert {} -trim outputfolder/{} \;
ImageMagick Batch Trim (mogrify)
While find allows for much greater control where output files will be placed, it is also possible to do the same with ImageMagick's mogrify:
And if you want to crop colors near the corner colors (adjust the percentage based on the results you are observing):
Please note that unlike convert and batch operation with find and convert, mogrify overwrites all files. To keep the originals use the -path option or do a backup copy of all images in the directory before proceeding with the mogrify command.
Side note: mogrify can be used to execute most (if not all) convert operations in batch, while overwriting original files.
As Trevor noted in the comments, you can use the -path option to output converted files to a new directory without overwriting the original files:
mogrify -trim -path trimmed_folder/ *.png
IrfanView
IrfanView runs quite nicely with Wine. Be sure to check the output of Irfanview carefully, as it sometimes breaks images when used with Wine.
Takkat
  • 144,580
