Cannot get my v600 usb scanner to work. Looking for epson drivers, I found this site. I downloaded drivers there :
  • iscan_2.29.1-5~usb0.1.ltdl7_amd64.deb
  • iscan-data_1.23.0-1_all.deb
and installed them. But my scanner is still not recognized. I use ubuntu 13.04. simple scan, iscan or xsane scan can not see the device.
Braiam
  • 69,112
I just got my Epson v600 scanner working on Ubuntu 18.04 by doing the following.
  1. Download and install the drivers from http://download.ebz.epson.net/dsc/search/01/search/searchModule
  2. create these linked files
sudo ln -sfr /usr/lib/sane/libsane-epkowa* /usr/lib/x86_64-linux-gnu/sane
  1. Create a file called /etc/udev/rules.d/79-udev-epson.rules with this content:
ATTRS{manufacturer}=="EPSON", DRIVERS=="usb", SUBSYSTEMS=="usb", ATTRS{idVendor}=="04b8", ATTRS{idProduct}=="*", MODE="0777"
  1. Power cycle the scanner.
If I didn't do step 3, I had to use sudo to run iscan. After including step 3 I could use the icon to launch iscan or launch it from the command line without sudo. I also tested the scanner with the XSane Image program and that works too.
rkeaing
  • 1,634
'Just found the solution !
I had used gdebi to install the three packages (iscan core, data and plugin). But, it is necessary to install EACH package one after the other as described here : http://download.ebz.epson.net/faq/linux/faq_ls_00002.html
Regards,
