I have a Sony VAIO S series with Windows 8 preinstalled and then I installed Ubuntu 12.10 partition.
The first time I was booting the Grub appeared, and I was able to choose between Windows 8 and Ubuntu 12.10. The problem is that when I select Windows 8 the Grub doesn't appear anymore and it boots always on Windows.
I read a bout this command in a Windows command prompt:
bcdedit /set {bootmgr} path \EFI\ubuntu\grubx64.efi
Seems like the command worked in the sense that you can see again the purple Grub menu at boot, and it also works when you select Ubuntu however, if you select to boot Windows 8 from Grub, you get the following two errors:
error: can't find command 'drivemap'
error: invalid EFI file path.
LiveWireBT
  • 29,597
