I've tried to install wine in ubuntu 12.10 through terminal. I write this script to install wine: sudo apt-get install wine but its is showing this error:
 wine : Depends: wine1.4 but it is not going to be installed
void@Void:~$ apt-get update
E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
E: Unable to lock directory /var/lib/apt/lists/
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
please tell me some solution for this problem or tell me some alternative to install wine in my system.
Alvar
  • 17,038
Jatin
Try this:
sudo dpkg --configure -a  # this will configure packages if needed
sudo apt-get install -f   # fix widespread packages errors
You may have to repeat these lines according to terminal's output. When it suggests you command, you should try that suggestion. And after you get rid of problems with packages, you should write this to install Wine:
sudo apt-get update       # update packages lists
sudo apt-get install wine # install wine
Danatela
  • 13,384
