After I installed codeblocks it started giving me error I'm getting loads of errors. I'm new to Ubuntu( from windows)
sudo dpkg --configure -a
dpkg: dependency problems prevent configuration of codeblocks-contrib:
codeblocks-contrib depends on libwxsmithlib0 (= 10.05-1); however:
Version of libwxsmithlib0 on system is 12.11-2.
codeblocks-contrib depends on codeblocks (= 10.05-1); however:
Version of codeblocks on system is 12.11-2.
dpkg: error processing codeblocks-contrib (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libwxsmithlib0-dev:
libwxsmithlib0-dev depends on libwxsmithlib-dev (= 12.11-2); however:
Package libwxsmithlib-dev is not installed.
dpkg: error processing libwxsmithlib0-dev (--configure):
codeblocks-contrib
libwxsmithlib0-dev
When I use Apt I get this error
sudo apt-get install gimp
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
codeblocks-contrib : Depends: libwxsmithlib0 (= 10.05-1) but 12.11-2 is to be installed
Depends: codeblocks (= 10.05-1) but 12.11-2 is to be installed
codeblocks-dev : Depends: libcodeblocks0 (= 10.05-1) but 12.11-2 is to be installed
gimp : Depends: libgimp2.0 (>= 2.8.4) but it is not going to be installed
Depends: libgimp2.0 (<= 2.8.4-z) but it is not going to be installed
Depends: gimp-data (>= 2.8.4) but it is not going to be installed
Depends: gimp-data (<= 2.8.4-z) but it is not going to be installed
Depends: libbabl-0.1-0 (>= 0.1.10) but it is not going to be installed
Depends: libgegl-0.2-0 (>= 0.2.0) but it is not going to be installed
Depends: libwebkitgtk-1.0-0 (>= 1.3.10) but it is not going to be installed
libwxsmithlib0-dev : Depends: libwxsmithlib-dev (= 12.11-2) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
-f isn't working either
apt-get -f install
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
sahil@sahil-ch:~$ sudo -s
root@sahil-ch:~# sudo dpkg --configure -a
codeblocks-contrib
libwxsmithlib0-dev
And when I use Software center it shows this error
New software can't be installed, because there is a problem with software currently installed. Do you want to repair this problem now?
And on prompting this error is shown
InstallArchives() failed: perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = "en_IN.ISO8859-1"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
LANGUAGE = (unset),
LC_ALL = (unset),
LANGUAGE = (unset),
LC_ALL = (unset),
LANGUAGE = (unset),
LC_ALL = (unset),
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 162153 files and directories currently installed.)
Preparing to replace codeblocks-contrib 10.05-1 (using .../codeblocks-contrib_12.11-2_i386.deb) ...
Unpacking replacement codeblocks-contrib ...
dpkg: error processing /var/cache/apt/archives/codeblocks-contrib_12.11-2_i386.deb (--unpack):
trying to overwrite '/usr/share/codeblocks/cb_koders.zip', which is also in package codeblocks-contrib-common 10.05-1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Unpacking libwxsmithlib-dev (from .../libwxsmithlib-dev_12.11-2_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libwxsmithlib-dev_12.11-2_i386.deb (--unpack):
trying to overwrite '/usr/include/wxsmith/properties/wxsflagsproperty.h', which is also in package wxsmith-headers 10.05-1
Preparing to replace codeblocks-dev 10.05-1 (using .../codeblocks-dev_12.11-2_i386.deb) ...
Unpacking replacement codeblocks-dev ...
dpkg: error processing /var/cache/apt/archives/codeblocks-dev_12.11-2_i386.deb (--unpack):
trying to overwrite '/usr/include/codeblocks/filefilters.h', which is also in package codeblocks-headers 10.05-1
Thank you :-)
