I know there was a lot of questions about this, but my problem is kind of different.
I have a tablet with Android. On Windows I used to host wifi from my PC. I used an application called connectify. On Ubuntu. I can use the "Use as hotspot" option but it hosts "Ad-hoc" network. Android doesn't see ad-hoc networks. How can I make a wifi network similar to what connectify did?
My PC is connected to Internet using a cable and I have external adapter.
Sorry for my english, and thanks for the help :)
Videonauth
  • 33,815
PoQ
  • 111
You can try ap-hotspot. It works with Android devices, but it has only two problems: no GUI and you can't share the network that you use to connect to the router (example: wifi connected - cannot share wifi).
sudo add-apt-repository ppa:nilarimogard/webupd8
sudo apt-get update
sudo apt-get install ap-hotspot
sudo ap-hotspot configure
sudo ap-hotspot start
The hotspot is now active and ready to go. The hotspot can be stopped by using the command:
sudo ap-hotspot stop
karel
  • 122,292
  • 133
  • 301
  • 332
-1
I believe if you have a wireless card you can click on the internet connections on the toolbar at the top of the screen and near the bottom there's an option to "create new wifi network"
