I enabled the kernel messages a long time ago because I was playing around with Ubuntu. But now I am finished and I want to disable them again, but forgot how to.
/etc/default/grub already contains the line:
#GRUB_TERMINAL=console
(including the hash which disables it).
Zanna
  • 72,312
Pixdigit
  • 165
The GRUB_CMDLINE_LINUX_DEFAULT definition in /etc/default/grub should contain "quiet splash". You also need Plymouth to be installed.
Zanna
  • 72,312
Gabriel
  • 719
Check if /etc/default/grub has the line GRUB_TERMINAL=console uncommented. Either open it with any editor, or just run this in the terminal:
cat /etc/default/grub | grep GRUB_TERMINAL
If the output is GRUB_TERMINAL=console without a #, then open the file with sudo -H gedit /etc/default/grub, add a # at the beginning of that line and save. Do not change anything else.
Zanna
  • 72,312
asheeshr
  • 793
  • 32
