here is my story :-)
i would like to get Bumblebee running with a NVIDIA® GeForce® GT 750M and it does not work. Basically optirun says Failed to initialize the NVIDIA GPU.
I tried many things suggested in here ending in a complete broke X server and unity after using nvidia-xconfig. after a night of debuging my system runs again (i had to reinstall ubuntu-desktop package), but something with the onboard intel chip is now broke too: before i hat 60 fps at glxspheres (running on the intel chip), now its 25fps.
Because GT 750M is not supported in 304, i installed the 319/325 Driver and bumblebee as described here:Using Nvidia 319 with bumblebee ( ppa:xorg-edgers/ppa )
in the following i try to post as much usefull information as possible:
System:
  • Details:http://www.asus.com/Notebooks_Ultrabooks/N550JV/#specifications
  • Processor: Intel® Core™ i7 4700HQ Processor
  • Memory: DDR3L 1600 MHz SDRAM, DIMM 8G
  • Graphic onboard: Integrated Intel® HD Graphics 4600 and
  • Graphic nvidia: NVIDIA®GeForce® GT 750M with 2GB DDR3 VRAM
  • Kernel: 3.8.0-30-generic
  • OS: Ubuntu 13.04 x64
optirun --debug glxspheres
[36773.371123] [DEBUG]optirun version 3.2.1 starting... [36773.371185] [DEBUG]Active configuration: [36773.371198] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf [36773.371211] [DEBUG] X display::8 [36773.371223] [DEBUG] LD_LIBRARY_PATH:/usr/lib/nvidia-325:/usr/lib32/nvidia-325 [36773.371236] [DEBUG] Socket path: /var/run/bumblebee.socket [36773.371248] [DEBUG] Accel/display bridge: auto [36773.371260] [DEBUG] VGL Compression: proxy [36773.371273] [DEBUG] VGLrun extra options:
[36773.371285] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus [36773.371349] [DEBUG]Using auto-detected bridge virtualgl [36773.411550] [INFO]Response: No - error: [XORG] (EE) NVIDIA(0): Failed to initialize the NVIDIA GPU at PCI:1:0:0. Please
[36773.411588] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) NVIDIA(0): Failed to initialize the NVIDIA GPU at PCI:1:0:0. Please
[36773.411593] [DEBUG]Socket closed. [36773.411613] [ERROR]Aborting because fallback start is disabled. [36773.411620] [DEBUG]Killing allremaining processes.
dpkg -l|grep nvidia
ii bumblebee-nvidia
3.2.1-1~raringppa3 amd64 NVIDIA Optimus support using the proprietary NVIDIA driver rc nvidia-304
304.108-0ubuntu1~xedgers~raring1 amd64 NVIDIA binary Xorg driver, kernel module and VDPAU library ii nvidia-319
325.15-0ubuntu1~xedgers~raring2 amd64 Transitional package for nvidia-319 ii nvidia-325
325.15-0ubuntu1~xedgers~raring2 amd64 NVIDIA binary Xorg driver, kernel module and VDPAU library ii nvidia-persistenced
325.15-0ubuntu1~xedgers~raring1 amd64 Load the NVIDIA kernel driver and create device files ii nvidia-settings-319
325.15-0ubuntu1~xedgers~raring2 amd64 Transitional package for nvidia-settings-319 ii nvidia-settings-325
325.15-0ubuntu1~xedgers~raring2 amd64 Tool for configuring the NVIDIA graphics driver
lspci -k | grep nvidia
Kernel driver in use: nvidia
grep -Fn '(EE' /var/log/Xorg.8.log
15: (WW) warning, (EE) error, (NI) not implemented, (??) unknown. 117:[ 36773.400] (EE) Failed to load module "kbd" (module does not exist, 0) 158:[ 36773.409] (EE) NVIDIA(0): Failed to initialize the NVIDIA GPU at PCI:1:0:0. Please 159:[ 36773.409] (EE) NVIDIA(0): check your system's kernel log for additional error 160:[ 36773.409] (EE) NVIDIA(0): messages and refer to Chapter 8: Common Problems in the 161:[ 36773.409] (EE) NVIDIA(0): README for additional information. 162:[ 36773.409] (EE) NVIDIA(0): Failed to initialize the NVIDIA graphics device! 163:[ 36773.409] (EE) NVIDIA(0): Failing initialization of X screen 0 168:[ 36773.409] (EE) Screen(s) found,but none have a usable configuration. 172:[ 36773.409] (EE) 176:[36773.409] (EE) Please also check the log file at "/var/log/Xorg.8.log" for additional information. 177:[ 36773.409] (EE)
kern.log
Sep 22 09:39:34 talorion-N550JV kernel: [37308.550024] vgaarb: this pci device is not a vga device Sep 22 09:39:34 talorion-N550JV kernel: [37308.550406] nvidia 0000:01:00.0: irq 50 for MSI/MSI-X Sep 22 09:39:34 talorion-N550JV kernel: [37308.563424] NVRM: failed to copy vbios to system memory. Sep 22 09:39:34 talorion-N550JV kernel: [37308.571915] NVRM: RmInitAdapter failed! (0x30:0xffffffff:720) Sep 22 09:39:34 talorion-N550JV kernel: [37308.571923] NVRM: rm_init_adapter(0) failed
Bumblebee.conf
KeepUnusedXServer=false XorgConfDir=/etc/bumblebee/xorg.conf.d
[bumblebeed] VirtualDisplay=:8 KeepUnusedXServer=false ServerGroup=bumblebee TurnCardOffAtExit=false NoEcoModeOverride=false Driver=nvidia
[optirun] Bridge=auto VGLTransport=proxy PrimusLibraryPath=/usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus AllowFallbackToIGC=false
[driver-nvidia] KernelDriver=nvidia-319 PMMethod=auto LibraryPath=/usr/lib/nvidia-319:/usr/lib32/nvidia-319 XorgModulePath=/usr/lib/nvidia-319/xorg,/usr/lib/xorg/modules XorgConfFile=/etc/bumblebee/xorg.conf.nvidia
[driver-nouveau] KernelDriver=nouveau PMMethod=auto XorgConfFile=/etc/bumblebee/xorg.conf.nouveau
Here are my question(s):
  • How can i go back to my graphical system working as it did right after the installation of ubuntu?
  • How can i get Bublebee run on mys System (or what exactly did i wrong)?
Thank you very much for any help.
Gregor
---UPDATE/EDIT---
after the suggestions of lupopa i installed 12.04 sucessuflly. the problem now is that nvidia prime is not working. why it is not working is decribed here: Is a NVIDIA GeForce with Optimus Technology supported by Ubuntu? . So i think i have to stick with bumblebee wich is still not working :-)
Gregon
  • 96
I was in the same situation as you few days back. I bought a new laptop Lenovo Y510P which had the following specs,
  • CPU: Intel Haswell Core i7 4700HQ
  • Memory: 8GB DDR3
  • Graphics Onboard: Integrated Intel® HD Graphics 4600
  • Graphic Nvidia: NVIDIA®GeForce® GT 755M
My advice (which I read in several places) is that you need to use the latest Ubuntu which in turn comes with the latest Linux kernel. I installed Ubuntu 13.10 (Unity) which comes with Linux Kernel 3.11.1 (at the time of writing this post).
Since I used Ubuntu 13.10, I had several advantages like not requiring to disable Secure Boot or anything. On inserting my installation CD, I pressed F12 to access the UEFI boot order, where I selected CD as the boot medium. I booted into the Live CD environment and things seemed to work well. So I installed it alongside with Windows.
After installing it, I rebooted which resulted in me getting a black screen after selecting Ubuntu from the Grub menu. I had to add the option -nomodeset. This was required since Ubuntu had defaulted to the nouveau drivers. Also I noticed that the brightness option was 0. So try increasing the screen brightness to see the ubuntu booting screen. However despite using the -nomodeset option, I still couldnt get into the login screen.
So I pressed Ctrl + Alt + F2 to get to the tty2 terminal. Here I logged in and installing the following,
sudo apt-get install bumblebee primus primus-libs-ia32:i386 linux-headers-generic
Then reboot the system. You will no longer need to add the -nomodeset option and was able to get to the login screen. I still have the issue of the brightness set to 0 on every boot. At this point, we are still using Intel HD4600 for all purposes alongside with the nouveau drivers.
On reading everywhere, the proprietary drivers for Nvidia are much better than Nouveau for new Nvidia graphic cards in terms of performance. So once logged in, I opened a terminal and executed the following,
sudo apt-get install bumblebee-nvidia nvidia-319 nvidia-settings-319
This will automatically pull in some additional packages as dependencies and ensure that bumblebee uses the nvidia proprietary drivers as default over nouveau. I did not have to edit any config files yet.
Bumblebee is currently our best option for Nvidia's Optimus technology. By default, Ubuntu uses Intel HD4600 for everything. If you want to run a game using Nvidia (not done automatically), append optirun --bridge primus to the command used to launch the game. Using this I am able to run Dota 2 on its highest setting and able to get 50-60 fps.
Hope this helped. I got all the information about bumbleebee at https://wiki.ubuntu.com/Bumblebee.
Note 1: At all costs, do not download the drivers from Nvidia's website and install them manually. If you do so, you will have to install the drivers again everytime there is a linux kernel update.
Note 2: Do not install nvidia-current since it still points at nvidia-304 which is quite old. I still need to figure out how to install nvidia-325 since its a newer driver version and bring more performance improvements.
Note 3: I haven't added the ppa:xorg-edgers/ppa yet since it is not yet available for Ubuntu 13.10. However once it becomes available, I intend to add it to get the latest updates to the intel HD4600 since this card is quite new.
nik90
  • 12,959
Install Linux Ubuntu 12.04.3 as new - Ubuntu using Nvidia Optimus as first device ;) And you don't need Bumblebee...
Greetings Lupopa
lupopa
  • 451
Got it working with my GT745M here on Ubuntu 13.10 on my Toshiba Satellite P50-A-11K laptop.
Not sure what is required, but here is what I did.
Installed drivers bumblebee and headers
sudo apt-get install nvidia-331 bumblebee linux-headers-generic
Open bumblebees config-file in gedit:
sudo gedit /etc/bumblebee/bumblebee.conf
Replace matching keywords with these values:
Driver=nvidia
KernelDriver=nvidia-331
LibraryPath=/usr/lib/nvidia-331:/usr/lib32/nvidia-331
XorgModulePath=/usr/lib/nvidia-331/xorg,/usr/lib/xorg/modules
Save and exit
I then removed 304-driver
sudo jockey-text -d kmod:nvidia_304
Then reconfigure some stuff, by running this and pressing ok.
sudo pam-auth-update --force
Rebooted.
This was a longshot, but the virtualGL-backend seem to be missing in 13.10, so I downloaded and install it from here: http://sourceforge.net/projects/virtualgl/files/VirtualGL/2.3.3/
Once downloaded, install in a terminal using:
sudo dpkg -i virtualgl_2.3.3_amd64.deb
optirun will now prefer virtualgl over primus (if bridge is set to auto or virtualgl in bumblebees configfile), and with the virtualgl-backend it seems to work fine.
Some output:
r@i7:~$ optirun -vvv glxgears
[ 2396.043994] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 2396.044237] [INFO]Configured driver: nvidia
[ 2396.044318] [DEBUG]optirun version 3.2.1 starting...
[ 2396.044325] [DEBUG]Active configuration:
[ 2396.044328] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 2396.044331] [DEBUG] X display: :8
[ 2396.044334] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-331:/usr/lib32/nvidia-331
[ 2396.044337] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 2396.044340] [DEBUG] Accel/display bridge: auto
[ 2396.044342] [DEBUG] VGL Compression: proxy
[ 2396.044345] [DEBUG] VGLrun extra options:
[ 2396.044348] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 2396.044372] [DEBUG]Using auto-detected bridge virtualgl
[ 2397.989470] [INFO]Response: Yes. X is active.
[ 2397.989482] [INFO]Running application using virtualgl.
[ 2397.989561] [DEBUG]Process vglrun started, PID 3727.
7045 frames in 5.0 seconds = 1408.869 FPS
6834 frames in 5.0 seconds = 1366.776 FPS
Eric Carvalho
  • 55,453
