Expected behavior (Ubuntu 10.04 LTS):
mike@boontoo10:~$ java -version
java version "1.6.0_45"
Java(TM) SE Runtime Environment (build 1.6.0_45-b06)
Java HotSpot(TM) 64-Bit Server VM (build 20.45-b01, mixed mode)
mike@boontoo10:~$ java -Xmx512m -Xms512m -jar forker.jar 10000000 20 Xmx512m Xms512m
output of "top":
1928 mike      20   0  694m  54m 8624 S    6  5.4   0:00.18 java
1933 mike      20   0  694m  54m 8648 S    6  5.4   0:00.18 java
1935 mike      20   0  694m  54m 8648 S    6  5.4   0:00.18 java
1939 mike      20   0  694m  54m 8648 S    5  5.4   0:00.16 java
(the java7 output looks like this on 10.04):
mike@ubuntu10java7:~$ java -versionjava version "1.7.0_40"
Java(TM) SE Runtime Environment (build 1.7.0_40-b43)
Java HotSpot(TM) 64-Bit Server VM (build 24.0-b56, mixed mode)
 2106 mike      20   0  734m  57m 9876 S    4  2.8   0:00.25 java
 2091 mike      20   0  734m  57m 9876 S    3  2.8   0:00.26 java
 2100 mike      20   0  734m  57m 9876 S    3  2.8   0:00.25 java
 2112 mike      20   0  734m  57m 9876 S    3  2.8   0:00.24 java
 2097 mike      20   0  734m  57m 9876 S    3  2.8   0:00.24 java
New behavior (Ubuntu 12.04 LTS):
mike@boontoo12:~$ java -version
mike@boontoo12:~$ java -Xmx512m -Xms512m -jar forker.jar 10000000 20 Xmx512m Xms512m
output of "top":
20697 mike      20   0 1405m  54m 8488 S    5  1.4   0:00.18 java
20669 mike      20   0 1405m  54m 8492 S    5  1.4   0:00.18 java
20691 mike      20   0 1405m  54m 8492 S    5  1.4   0:00.17 java
20658 mike      20   0 1405m  54m 8492 S    5  1.4   0:00.17 java
Update: New behavior (Ubuntu 12.04 LTS w/ Java 7):
mike@boontoo12java7:~$ java -version
output of "top":
 4166 mike      20   0 1438m  56m 9572 S    7  2.8   0:00.20 java
 4169 mike      20   0 1438m  56m 9572 S    7  2.8   0:00.20 java
 4182 mike      20   0 1438m  56m 9572 S    7  2.8   0:00.20 java
 4076 mike      20   0 1438m  56m 9572 S    6  2.8   0:00.19 java
 4100 mike      20   0 1438m  56m 9572 S    6  2.8   0:00.19 java
ctd... 12.0.4 with OpenJDK 6, similar problem:
java version "1.6.0_27"
OpenJDK Runtime Environment (IcedTea6 1.12.6) (6b27-1.12.6-1ubuntu0.12.04.2)
OpenJDK 64-Bit Server VM (build 20.0-b12, mixed mode)
output of "top":
 6690 mike      20   0 1500m  55m 8920 S    7  1.4   0:00.22 java
 6692 mike      20   0 1500m  55m 8920 S    7  1.4   0:00.21 java
 6697 mike      20   0 1500m  55m 8920 S    7  1.4   0:00.21 java
 6701 mike      20   0 1500m  51m 8684 S    7  1.3   0:00.21 java
 6725 mike      20   0 1500m  55m 8920 S    7  1.4   0:00.21 java
To preempt, here's the OpenJDK 7 attempt:
java version "1.7.0_25"
OpenJDK Runtime Environment (IcedTea 2.3.10) (7u25-2.3.10-1ubuntu0.12.04.2)
OpenJDK 64-Bit Server VM (build 23.7-b01, mixed mode)
output of "top":
 9327 mike      20   0 1534m  57m 9296 S    6  1.4   0:00.25 java
 9331 mike      20   0 1534m  57m 9276 S    6  1.4   0:00.25 java
 9344 mike      20   0 1534m  57m 9300 S    6  1.4   0:00.25 java
 9347 mike      20   0 1534m  57m 9300 S    6  1.4   0:00.25 java
 9323 mike      20   0 1534m  57m 9300 S    6  1.4   0:00.25 java
 9284 mike      20   0 1534m  57m 9308 S    5  1.4   0:00.24 java
 9285 mike      20   0 1534m  57m 9300 S    5  1.4   0:00.24 java
 9336 mike      20   0 1534m  57m 9276 S    5  1.4   0:00.23 java
 9277 mike      20   0 1534m  57m 9300 S    5  1.4   0:00.24 java
As you can see, the vmem utilization has doubled. I'm using the exact same java/jre binary (and jdk), the only difference being the version of Ubuntu.
I'm hoping to get this program back to ~694m of vmem used. How do I do that? What do I even search for?
Please don't suggest that I structure my program differently. This is the smallest toy-example I could write to reproduce a gigantic problem reflected in some Apache Software, but this feels like a kernel/libs problem to me.
Here's the code to duplicate, and the link where all this is summarized in a gist: https://gist.github.com/michael-trelinski
Code:
package com.satoricode.forker;
import java.util.concurrent.ExecutorService;
import java.util.concurrent.Executors;
public class ForkIt {
  public static void main(String[] args) throws InterruptedException {
        int arraySize = Integer.parseInt(args[0]);
        System.out.print("Filling up some memory... ");
        int[] arr = fillItUp(arraySize);
        System.out.println("" + arr.length + " done.");
        if (args.length == 1) {
            System.out.println("I'm the fork!");
            Thread.sleep(10 * 1000);
        } else {
            // I'm the master
            int numForks = Integer.parseInt(args[1]);
            String stackCommand = args[2];
            String stackInitCommand = args[3];
            ExecutorService pool = Executors.newFixedThreadPool(numForks);
            System.out.println("Launching " + numForks + " forks with array size " + arraySize + " with -" + stackCommand + " -" + stackInitCommand);
            for(int I = 0; I < numForks; I++)
                pool.execute(new ForkRunner(arraySize, stackCommand, stackInitCommand));
            pool.shutdown();
            System.out.print("Waiting for pool to finish");
            while(!pool.isTerminated()) {
                Thread.sleep(50);
                System.out.print(".");
            System.out.println();
            System.out.println("done\n");
    private static int[] fillItUp(int total) {
        int[] arr = new int[total];
        for (int I = 0; I < total; I++)
            arr[I] = I;
        return arr;
import java.io.IOException;
import java.io.InputStream;
public class ForkRunner implements Runnable {
  private String stackCommand;
    private int arraySize;
    private String stackInitCommand;
    public ForkRunner(int arraySize, String stackCommand, String stackInitCommand) {
        this.arraySize = arraySize;
        this.stackCommand = stackCommand;
        this.stackInitCommand = stackInitCommand;
    @Override
    public void run() {
        try {
            String command = "java -" + stackCommand + " -" + stackInitCommand + " -jar forker.jar " + arraySize;
            System.out.println("executing: " + command);
            Process proc = Runtime.getRuntime().exec(command);
            InputStream input = proc.getInputStream();
            InputStream error = proc.getErrorStream();
            StringBuilder sb = new StringBuilder();
            int c = -1;
            while ((c = input.read()) != -1) {
                sb.append((char) c);
            while ((c = error.read()) != -1) {
            System.out.println(sb.toString());
        } catch (IOException e) {
            e.printStackTrace();
Alaa Ali
  • 32,213
