Basically, the short answer is "Yes" and the complement of such answer will be "Use the rhythmbox-client command from a terminal in order to control your current running Rhythmbox, if it is not already loaded the first instance of your commands will invoke it."
In example: rhythmbox-client --play will make the current Rhythmbox session to start playing the current song (or the first song in the list). If Rhythmbox is closed then it will open it first in order to start playing.
Further information about the rhythmbox-client and its usage can be reached in the rhythmbox-client man page. I place here a portion of the manpage just for reference.
NAME
rhythmbox-client - controls a running instance of rhythmbox
SYNOPSIS
rhythmbox-client [option...][file...]
DESCRIPTION
rhythmbox-client is a tool for controlling an already running instance
of rhythmbox. It's useful for remote control scripting, adding
specific files to the library from the shell, or printing details of
what's playing. It also has an interactive mode, useful for controlling
playback remotely via ssh. Any files specified after the option
arguments will be added to the library. If the --enqueue option is
given, the files will also be added to the play queue.
OPTIONS
-?,--help
Show help options
--debug
Enable debug output
--no-start
Do not start a new instance of rhythmbox
--quit Quit rhythmbox
-i,--interactive
Start interactive mode --no-present Don't present an existing
rhythmbox window
--next Jump to next song
--previous
Jump to previous song
--play Resume playback if currently paused
--pause
Pause playback if currently playing
--play-pause
Toggle play/pause mode
--stop Stop playback if currently playing
--play-uri=URI
Play a specified URI, importing it if necessary
--enqueue
Add specified tracks already in the library to the play queue
--clear-queue
Empty the play queue before adding new tracks
--print-playing
Print the title and artist of the playing song
--print-playing-format=format
Print formatted details of the song (see FORMAT OPTIONS below).
--set-volume
Set the playback volume
--volume-up
Increase the playback volume
--volume-down
Decrease the playback volume
--print-volume
Print the current playback volume
--select-source=URI
Select the source corresponding to a URI (device or mount point)
--activate-source=URI
and start playing from it if not already playing.
--play-source=URI
and start playing from it.
FORMAT OPTIONS
%at album title
%aa album artist
%aA album artist (lowercase)
%as album artist sortname
%aS album artist sortname (lowercase)
%ay album year
%ag album genre
%aG album genre (lowercase)
%an album disc number
%aN album disc number, zero padded
%st stream title
%tn track number (i.e 8)
%tN track number, zero padded (i.e 08)
%tt track title
%ta track artist
%tA track artist (lowercase)
%ts track artist sortname
%tS track artist sortname (lowercase)
%td track duration
%te track elapsed time
Variables can be combined using quotes. For example "%tn %aa %tt", will
print the track number followed by the artist and the title of the
track.
AUTHOR
This manual page was written by Sven Arvidsson <sa@whiz.se>, for the
Debian system (but may be used by others).
Edit
I got some interest on this subject so I ran a test with the next command:
dbus-send --print-reply --dest=org.mpris.MediaPlayer2.rhythmbox /org/mpris/MediaPlayer2 org.mpris.MediaPlayer2.Player.Seek int64:60000000
From the original answer posted right here. Which indeed works for the task of seeking on current playing song, (based on the asker's comment).
Good luck!
