So I had a full /boot and I've really messed things up now. What I'd really like to do is run sudo apt-get purge linux-image-3.2.0-{35,36,37,38} but I need to fix these other problems first. So when I run sudo apt-get -f install this is what I get (I also get similar output for any other apt-get commands)
$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following extra packages will be installed:
linux-generic-pae
The following packages will be upgraded:
linux-generic-pae
1 upgraded, 0 newly installed, 0 to remove and 192 not upgraded.
1 not fully installed or removed.
Need to get 0 B/1,726 B of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]?
dpkg: dependency problems prevent configuration of linux-generic-pae:
linux-generic-pae depends on linux-image-generic-pae (= 3.2.0.41.49); however:
Version of linux-image-generic-pae on system is 3.2.0.53.63.
linux-generic-pae depends on linux-headers-generic-pae (= 3.2.0.41.49); however:
Version of linux-headers-generic-pae on system is 3.2.0.53.63.
dpkg: error processing linux-generic-pae (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
linux-generic-pae
But this doesn't tell me enough what the other error was. I think it started when I ran sudo apt-get -f install with only about 20MB of free space in /boot. Grrr, /boot partition is super annoying.
